Carter Lumber Pole Building kit info
   / Carter Lumber Pole Building kit info #21
I guess there delivery is just store by store.
My last delivery, which also happened to my my first, was a royal cluster.
Menards contracts out the deliveries.. and many dont stay long as its just a way to pass time while waiting for a bigger contract. I have seen 3 different people while doing a 6 week job once. Only one was actually good or cared. He also was the guy who was there the shortest time.
   / Carter Lumber Pole Building kit info #22
They now only offer the discount to veterans three days per year. :-(
I get it every time I go in.. Just ask and flash your ID. Current or Retired Military or VA ID works.. If you are a vet and dont have an ID, go to your local VA Clinic/Hospital and apply to enroll. Once you are enrolled, you should get a VA ID card that you can then use.
Well there's no Menards for a few hundred miles and I'm not in the military.......
So does anyone have experience with the metal trusses?
Also looking into using a steel frame like Strat-O-span.
   / Carter Lumber Pole Building kit info #24
No experience with building with metal. But it was all quite a bit more expensive when I was pricing.
And would either be difficult to build myself or require equipment I didn't have. And insulating/finishing the interior is more challenging
Do you remember what type or brand you priced out?
So far it looks to be pretty close in price.
What type of special equipment did you need? Beams and uprights appear to all bolt together on the Strat-O-span. Also looks like the insulation and interior finishing would be about the same.
Seems like the metal framework would go up quicker and easier then wood and trusses.
Just need to do some more pricing on the exterior stuff to see how they compare.
   / Carter Lumber Pole Building kit info #26
No I dont remember who/where I called. I quickly ruled out all metal. Those beams require footers with properly spaced lags and are heavier to set than building a wood wall. As far as insulation, if you are fine with the 2" thick stuff or whatever it is that they line the insides with...then fine. I wanted 6" walls and 6" insulation. And I wanted a flat bottom on the truss to attach a ceiling and blow in ~R38 worth in the ceiling. Metal buildings have odd spacing on the wall girts, usually 4' or so. Kinda rules out fiberglass batts. And that thin stuff made for metal buildings was pricey for the R-value. As far as interior finishing, I like metal liner panel ceiling and painted OSB walls. That way I can drive a nail or screw and hang whatever I want. Or locate studs and build shelves or whatever. Kinda hard to do those things on an all metal. So I quickly talked myself out of it.
I did price the trusses a little more seriously though. Still about double the cost for 40' span trusses. Thats not double per truss, cause you only use half or less metal trusses. That was double for the job. And long spans, with 2x6's on edge for purlins....just didnt like it. I like 4' OC and 2x4's flat for more area to hit with roofing screws. Not to mention the flat bottoms for ceiling and insulating reasons. A vaulted ceiling, is just more air that I cannot use inside the building but cost money to heat/cool.
I think we are talking about differnt types of metal framing.
The ones I'm looking at aren't the 2x2 box but actual beams spaced 10' OC, I'd have to frame out for the interior either way with a pole barn so don't think that'll be an issue. I actually want the vaulted ceiling for more clearance above the lift and more headroom for when I build the mezzanine, can't really increase my wall height any more.
It's all going to come down to cost so once I get going with material list and shopping around I'll know more.
   / Carter Lumber Pole Building kit info #28
A little late to this thread but - OP - did you check 84 lumber?
I was pricing for building a 20x12 shed and their "kit" was basically just a good list of materials which they generated at some HQ location but in talking with the guy in Manassas it would have been trivial to change and they had the best prices.
   / Carter Lumber Pole Building kit info #29
Nope, same type kits. The beams are what would be difficult to set. More so than wood. And they use a z-channel or light weight c-channel running horizontal between posts for metal to attach.
Depends on how you frame your polebarn, will depend on the level of difficulty of finishing the inside.
I ended up going stick built on a block foundation, but had I gone the post-frame route, My wall girts were NOT gonna be the standard 2x4 on the outside. Rather I was gonna use 2x6 and be flush with both the inside and outside of the 4x6 or 6x6 posts.
Here is how I would have done it Higgins & Sons Buildings - RTF Wall Girt System
Would take a tad longer to put the shell up, but if finishing the inside, it saves on time and material in the long run.
That's a nice setup there but 6" wall overkill and most likely add too much cost for me, the outside is going to be sheathed in osb have matching siding to the house instead of metal paneling.
I've been looking at stick built but appears to be out of the budget.
I've watched large metal framed buildings being constructed, believe it was made by General steel, seem pretty easy to put up.
Newberry, 84 didn't have anything I liked when I looked a few years ago, plus I've had problems with them in the past and decided not to use them anymore.
2020 Topcat 48" Hydraulic Articulating Skid Steer Cutter Attachment, S/N BORC20120101, Asset# 69 (A59076)
2020 Topcat 48"...
2018 CHEVROLET SILVERADO CREW CAB TRUCK (A58375)
2018 CHEVROLET...
Giyi Mini Pallet Forks (A57149)
Giyi Mini Pallet...
TANK MANIFOLD (A58216)
New/Unused 14ft Bi-Parting Iron Gate (Cow Design) (A57454)
New/Unused 14ft...
2018 Ram ProMaster 2500 Passenger Van (A56858)
2018 Ram ProMaster...
