carrying wood with 200cx ?????
   / carrying wood with 200cx ????? #1
meb9796
VA
JD 3720
I'm putting in 600' of fence in June and I'm looking for a way to carry the poles and boards with my FEL. I'm thinking some of those modified pallet jacks that clamp to your FEL but can't find any. I know most people make their own (my welding class is coming up next month!!:) ) but was wondering if there was any place I could look at them for an idear.
thanks!!
   / carrying wood with 200cx ????? #2
harbor freight and northern tool come to mind real fast but check with local dealer he may have em.
   / carrying wood with 200cx ????? #3
It was Nov. 07 when I picked up a set at the local metal scrap yard for $150,
they must have 100 pairs or more, I had a hard time deciding which pair I wanted, I knew I was going to be picking up a lot of pallets, so I knew I want them to be close to 48".
I also picked up a piece of 4x4 angle about 60" long to strap to my bucket
to hang the forks on temporally .
Here's a small assortment of what they had to offer.
   / carrying wood with 200cx ????? #5
Meb9796, I bought used forks and to Deere for the loader mounts then had a welding shop make these. Also mounts to the 3pt.
   / carrying wood with 200cx ????? #7
excelagator said:
New,
Do you or anyone know the part #s for the JD quick parts for the FEL??
W43359 HOOK
W47211 PIN
   / carrying wood with 200cx ????? #8
I've been moving some 12ft pallets around the property (oak, used for sheet metal). What I did is put one in lengthwise into the bucket, curled and lifted to catch the upper lip (512 loader) until off the ground. Loaded the rest and moved them to where I needed them. Not as eligant but it worked.
2015 Toyota Prius Hybrid Sedan (A56859)
2015 Toyota Prius...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
LOT: Torch Cart w/Gages, Hose, Torch Head (TANKS NOT INCLUDED) (A59076)
LOT: Torch Cart...
Kubota BX25D (A53317)
2009 PETERBILT 340 FLATTOP SLEEPER (A58214)
2009 PETERBILT 340...
2009 IC Corporation PB105 School Bus (A55973)
2009 IC...
