CarryAll, how to make one? or, where to buy one?
   / CarryAll, how to make one? or, where to buy one? #11
The KK carryall is a nice unit for the money. I bought one last fall and used it to convert my pull type lawn vauum to a 3PT. The only downside I can see with that design is that it allows a lot of "twist" if the load is not centered. Once I had my vacuum mounted and welded the two frames together it became very stiff and works great. Some 2x12s bolted to vertical front and the horizontal bottom angles would add a lot of stiffness if used as a platform carrier. If I was to use one as a forklift I would at least add the 2x12s to the vertical angles or better yet a piece of plate steel at least 3/8" thick. However that would add a lot of weight and could be expensive, too.
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2015 Chevrolet 1500 Silverado Pickup Truck (A55852)
2015 Chevrolet...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2015 Ford F450 SD Flatbed (A52377)
2015 Ford F450 SD...
2008 Sterling Acterra Ambulance (A56858)
2008 Sterling...
(INOP) CATERPILLAR 314 EXCAVATOR (A51247)
(INOP) CATERPILLAR...
