Carry All box and adding weight to the front of a Ford Powermaster 851?
   / Carry All box and adding weight to the front of a Ford Powermaster 851? #1
Gasifier
Platinum Member
St. Lawrence River Valley, N.Y.
2013 Kubota L5460HSTC
Hey guys. Been a while since I have been on this site. I have purchased some property and a Ford 851 Powermaster. I just built a wood box on top of a carry all frame I bought at Tractor Supply that was rated at 1000 lbs for the frame. I don't plan on loading it that much but some have advised me I may need some ballast on the front of the tractor to keep the front on the ground and steering capable. Has anyone added weight to the front of their Ford 851 Powermaster or a tractor that is similar? Or do you know what might be the best, and preferable cheapest way to add some weight to the tractor. If I can get on the site from my phone I will add some pics of the wood box project. Thanks in advance for any help you can give. It is appreciated.
Here s an attempt at a few pics. Well having a prob posting pics from I-phone. Any suggestions?
   / Carry All box and adding weight to the front of a Ford Powermaster 851? #3
I didn't see pics, but I'm assuming you don't have a loader. With loader, the solution is simple...just put wood in the bucket as well as in the carryall. Otherwise, I think adding some weight on the front is likely a good idea if you are going to really load up the carryall. I loaded my TSC carryall heavily enough to crack a weld and need repair...but the carryall frame didn't actually bend.
Bob
Nope. No loader on the Powermaster. I have a Bobcat B300 T/L/B with a cab. But the Powermaster is a lot lighter, and with no cab can get around in the woods easier. It looks similar to this. Not as nice, but it is getting there. LOL I'll post a pic of mine with the carry all wood box I built when I have time at home and can use the right computer. For some reason I can not upload my images from my I-phone.
Try pictures again. After I hauled some wood out I cleaned the tractor up a bit. Looks a little better in the first pic.
I ended up selling this tractor just the other day. I am going to upgrade to a four wheel drive. Kept the heavy duty York rake and the carry all box to use with the next tractor.
Some more. The process.
Well the order isn't coming out right, but you get the picture. The P.T. Wood was saved from an old deck we use to have. Perfect for this job.
NEW Landhonor 5400LB Ratchet Binders & G70 Chains (A59000)
NEW Landhonor...
16001 (A55853)
16001 (A55853)
2018 RAM 2500 (A58214)
2015 GMC Terrain SUV (A56859)
2015 GMC Terrain...
2018 Ford F-350 (A55973)
2018 Ford F-350...
1992 DFI PULL SPREADER (A58375)
1992 DFI PULL...
