Carry a Fire Extinguisher: A cautionary tale.
   / Carry a Fire Extinguisher: A cautionary tale. #11
I thought that extinguishers that were meant for automotive (fuel) fires were white (not red) ??
   / Carry a Fire Extinguisher: A cautionary tale. #12
You might want to consider Element - Fire Extinguishers as its small enough to carry on an ATV and has 5 times the output of the typical extinguisher. Not cheap but neither was the repair.
There is a tradeoff - there should be no concern about replacing them after 6 years.
   / Carry a Fire Extinguisher: A cautionary tale. #13
Maybe wherever you live. But Kidde seems to reserve white for marine.
And in the US red is for class B - liquids
Fire extinguisher - Wikipedia
   / Carry a Fire Extinguisher: A cautionary tale. #14
The designation is "Marine/Auto"
AutoZone has a nice one with a metal mount for 25 bucks.
https://m.autozone.com/safety-and-security/fire-extinguisher
That's a good deal on an ABC (which is what you want for gas and electrical fires), but I wanted one that was specific for UTV roll cage mounting with a mount that could take a beating as a modern RZR is like a munchkin trophy truck and a driver can rock along in a ditch at 50-60 miles per hour, no problem.
Eric, I am glad your O.K. and sorry about the RZR.
Please tell me you weren't hauling gas in the back.
Yes I watched the video.
Yup. I was hauling a full 6 gallion gas can in the back and when I threw it, as it was on fire, I had the presence of mind to not that it was still sealed. Even so, I presume (but don't know) that gas leeched down the bungee cord and hit the hot exhaust. All I know is I was banging over a driveway following a ditch, heard a big *WHooPHfff* an lost power in moments. A friend's son is a Polaris tech and said his manager would like to see my RZR because there is a heatshield recall. So I'll trailer it over there within the week (if it ever warms up here in northern Minnesota).
   / Carry a Fire Extinguisher: A cautionary tale. #19
Turbochargers and catalytic converters get hot enough to flash gasoline into flames. If you have either, a fire extinguisher is a great idea. My own engine fire was on the racetrack about 17 years ago. Turbo.
One fire is more than enough.
   / Carry a Fire Extinguisher: A cautionary tale. #20
Eric - I am so glad to see that you are OK. One frightening experience.
Back in the day - about 30 or so years ago - I used firewood to heat the house. I had a LARGE 75 pound ABC on large wheels. I would wheel it out to where we were cutting & splitting.
Didn't so much worry about the tractor catching on fire. It was the splitter. Hot hydraulic oil, gasoline & hot exhaust. And actually I was not so concerned about the splitter burning up either.
The big concern - ANY fire out on my property could easily be the point source for a major wildfire.
I never had to use it. Had it recharged/serviced and sold it to a logging contractor.
Compressor (A55973)
Compressor (A55973)
Mower King SSRC72 QA 72" Brush Cutter (A57149)
Mower King SSRC72...
(4) DUAL 6 LUG WHEELS (A58376)
(4) DUAL 6 LUG...
Scotchman 9075C1280 Hydraulic Press (A59213)
Scotchman...
LOT: (2) Shelves of Komatsu Parts & Filters (CONTENTS ONLY) (A59076)
LOT: (2) Shelves...
CFG Industrail MX15RX (A53317)
CFG Industrail...
