Caroni TM1900 Flail-1st Impressions
   / Caroni TM1900 Flail-1st Impressions #1
skipperbrown
Platinum Member
Pensacola Fl, Birchwood TN
Kubota b2650, bx2200, L3940 (gone), New Holland FWD TN85, RTV 900
I bought a TM1900 from Agri Supply and used it about 8 hrs last weekend to mow 12 food plots which averaged about an acre each. This is the first time this year the plots have been mowed and they consisted of mostly bitterweed, briars, johnson grass, and wheat/oat stubble. I have a Bota 3940 and ran it a couple hundred rpm under pto speed. The cutting height was set at 3.5" at the bottom of the Y shaped blades and 4" at the top.
My mowing speed mostly ranged from 2.5 to 3.7 mph. I couldn't mow any faster than that due to the roughness of the land, but I think this is about the top speed without spinning it faster. My average speed was probably 3 to 3.2 mph.
The 5 to 7 ft johson grass really worked the mower and the tractor. It was thick and heavy. When the tractor started to strain and the mower sound told me it was really working, I could take it at 2 mph.
Overall, I am very pleased. The bitterweed was the toughest customer. A lot of it was bent over and not cut or only half cut. Part of the problem was the tires pushed it over and it didn't spring back up fast enough before entering the cutters. However, bitterweed is a also problem for my woods 6' brushcutter.
My buddies and I were all impressed by the cut and how compact the tractor/flail were on the trailer.
On inspection after I got it cleaned up, I found I lost 2 bolts on the top link support. My fault for only making them tight and not "real" tight. I also noted that most of the knives had slung back and impacted the drum dulling the trailing edge. The front edge was duller too. I attribute this to mowing a crowned road too closely. I pulled the belt cover and found belt dust, but the belts seemed to be in good shape. Not sure if this is normal wear or if I had some slippage. I will buy another set and carry them with me.
What I like best is how easy it is to trailer over a brush cutter (about 3' vs. 10') and when you turn, you aren't slinging 10' of cutter around. It also cuts very good. It's quieter than a brush cutter and weighs less. The clippings fall randomly behind the cutter and don't windrow.
Things I don't like is that it doesn't cut well on a sharp turn and the skids can dig a trench if you don't lift it. I also worried about smoking my belts but that didn't happen.
I did the dip stick mod and had no oil leakage at all. If it holds up for years, I'll be a happy camper. So far I'll rate it a very nice medium duty general purpose mower that is ideal for those who need to trailer their equipment.
   / Caroni TM1900 Flail-1st Impressions #2
I own a NH Flail and took the skids off.
   / Caroni TM1900 Flail-1st Impressions #3
Nice review presentation. I have a Kubota L4310 and use a 5' rotary mower.
What type of knives or hammers did you order?
What happens when the mower hits rocks?
   / Caroni TM1900 Flail-1st Impressions #4
I haven't had the problem you describe with the skids. I know what you are talking about as it was a major problem with my old Bush Hog Squealer but I just haven't seen that with my TM1900. I don't tend to lower the mower all the way to the ground except when I specifically am trying to mulch up some debris so maybe that is the difference. I also use a hydraulic topping lift and may have that adjusted to tilt the mower back a bit more than you do so you might try that. In general the mower rides on the rear roller and shouldn't really be on the skids. I've thought about taking mine off as they sometimes snag brush and don't seem to serve much purpose but as I noted, I haven't had trouble with gouging on turns.
ITEM LOCATION (A53084)
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
INOP/NON-RUNNING Chevrolet Rollback (A51572)
INOP/NON-RUNNING...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A52748)
John Deere 5090E...
2239 (A51244)
2239 (A51244)
1999 Volvo VN Truck, VIN # 4VA7BBJF9XN770848 (A51572)
1999 Volvo VN...
