DJ54
Elite Member
- Joined
- Jan 20, 2009
- Messages
- 4,520
- Location
- Carroll, Ohio
- Tractor
- IH Farmall 656 gas/ IH 240 Utility/ 2, Super C Farmalls/ 2, Farmall A's/ Farmall BN/McCormick-Deering OS-6/McCormick-Deering O-4/ '36 Farmall F-12/ 480 Case hoe. '65 Ford 2000 3 cyl., 4 spd. w/3 spd Aux. Trans
I did a quick check, and looks like that carb had a drain plug in the bowl, and just guessing it's 1/8" NPT. I read a thread several years back, on a fellow having the same problem. To get the float set to where the fuel level was correct, although not to specs., he removed the plug, and installed a barbed fitting. He then slipped clear tubing on the fitting, long enough to turn up 180º along side the carb., a good bit above the fuel level. Then, turning the fuel on, will allow you to see the fuel level inside the bowl. Just keep tweeking the float, until you have the proper level. Once you have the float set, you can always leave it set for a while, and check to see if it's letting fuel by the needle.
I know back in the 70's when I was showing tractors, nearly everyone had to reset their floats, due to the different specific gravity of the unleaded fuel. I have to think that adding ethanol has to change it even more.
