Carburator Issues
   / Carburator Issues #1
outinthepines
Rutherford, NC
MF 135
Newbie here! I have an early 70's MF 135 gas engine and have run into a road block. While cold or sometimes running at idle speed my 135 will start to choke down, sounds like its running out of fuel but I can pull out the choke and limp it back to the shop. I've rebuilt the carb, new fuel filter, carb bowl is clean, its getting plenty of fuel. What next? A new carb cost around 260, any suggestions?
   / Carburator Issues #2
You could have junk in the fuel tank, Remove the fuel line from the carb and run some fuel into a large canning jar. You should see if anything is floating in your fuel.
   / Carburator Issues #4
If it acts like it is running out of fuel at higher speeds I've found a blocked fuel tank/cap vent to be the problem... doesn't sound like what you are experiencing.
I've had a lot of fuel issues with older equipment with reformulated fuels and that is just about all that is available here...
One was so bad I had to pull the tank to clean it and no more problems...
UNUSED FUTURE X-PG44- 44" MINI HYD GRAPPLE BUCKET (A54757)
UNUSED FUTURE...
2019 TRAIL KING INDUSTRIES ADVANTAGE PLUS TRIAXLE RGN W/FLIP AXLE (A55745)
2019 TRAIL KING...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
SINGLE AXLE 2 DISC SPIN SPREADER (A54756)
SINGLE AXLE 2 DISC...
UNUSED TOY REMOTE CONTROLLED CRANE TRUCK (A54756)
UNUSED TOY REMOTE...
2008 Isuzu NPR-HD Landscape Dump Truck (A53422)
2008 Isuzu NPR-HD...
