Carburator for JD 214 w/ K321 motor...
   / Carburator for JD 214 w/ K321 motor... #1
JamesP
John Deere 4020
Got an old 214 for $600 a few years ago. Its seen its better days but for the price, i like it. I had to replace the fuel pump on it and a few other miscelaneous parts recently. Got it all back together and it wont crank. It ran slick as a button before the fuel pump diaphram gave out. It caught on fire at the carb when i tried to fire it up.
I have adjusted the points, disassembled the carb to clean and set at the initial setting according to the manual, installed new fuel line and i cant figure it out. I have cleaned the carb out several times before and it worked fine. Did nothing different this time. Im looking to get another carb but a new one is around $260!
I just lost a deal on Ebay for a used one for 60 bucks. Guess i was too slow. Any secret sites for a better price? Best i could tell, the part # is 4705363 but the stamp was not clear. I couldnt find that part # on openengines.com but several real close.
Anybody know where to find a used K321 carb?
   / Carburator for JD 214 w/ K321 motor... #5
James, have you checked out other things? Do you have spark, compression. Are you getting fuel? Spray a little fuel in the carb. & see if it fires. If it ran fine before, why would you think the carb. is bad when you didn't do anything to it?
2013 John Deere 824K (A52748)
2013 John Deere...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
2022 Third Coast Reversible Plate Compactor (A51573)
2022 Third Coast...
Toro Mower (A50324)
Toro Mower (A50324)
2012 Ford Explorer (A50120)
2012 Ford Explorer...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
