carbon monoxide poisoning
   / carbon monoxide poisoning #1
tglass
Platinum Member
3320 w/cab
Don't really know alot about the detectors. Carbon monoxide alarm. Have one that runs off batteries and hear there is one that runs off 120V with a battery backup. Anyone have one of these and if so how do you know when the batteries need replacing. And what about the cost other than the usual what what is your life worth salesman classic. If they exist, how are they priced?
   / carbon monoxide poisoning #2
I have two that are 120v (one has battery backup). Not really sure how long the batteries last since I change them when we reset the clocks. Cost is about $70 & up.
   / carbon monoxide poisoning #3
I tried to put a battery powered one in my trailer that I use as a mobile shop. It is too sensitive for my use, I have too many chemicals on hand. I think my solvent tank sets it off. I would really like to have one.
I did nearly kill myself about 8 years ago. I had my air compressor mounted inside the trailer and had the exhaust routed to the outside. Typically I ran it with the doors open, but it was cold, so I was running it with the doors closed. I thought I would be okay with the exhaust being ran outside. I didn't notice that the muffler had a crack in it. I started to feel light headed and went outside and sat down. I have no idea how long I was unconscience but when I came to, I realized that I had pissed myself at some point. I am lucky I went outside when I did.
Brian
   / carbon monoxide poisoning #4
Don't underestimate carbon monoxide, years ago, I would spend weekends on a boat on the Potomac River in Western MD. One Fall, the temp dropped considerably in the evening so I brought an almost burned out charcoal grill into the small cabin, and hit the bunk. I was found by a friend, on the river bank the next morning, about 50 yards from the boat. I don't recall ever being more sick. Be careful.
   / carbon monoxide poisoning #5
Nasty stuff for sure, got a bit myself finishing a floor in a basement with a power trowel, had the windows open but wasn't enough. They are a common accessory for wood stoves as they choke the fire down and are more prone to it. I have had no problems with masonry stoves which burn full on until done but then still use only an 80% damper for the safety factor.:)
   / carbon monoxide poisoning #6
When we were full time RVers, both of the RVs we lived in had battery powered CO monitors in the bedroom. When the batteries needed changing, the monitor would start to chirp, which can be annoying in the middle of the night.:laughing: So I decided to just change them every 6 months before they started chirping.:)
   / carbon monoxide poisoning #7
A carbon monoxide alarm save my life. Few years ago the air intake/exhaust for the furnace was drifted shut by snow. The furnace repeatedly attempted to start and then would shut off. That caused carbon monoxide to build up indoors (not suppose to happen but did) setting the alarm off. Happened at night so without the alarm it's likely wife and myself would have been history! We have the First Alert 120V alarms that just plug into outlets (no battery backup). As I recall they were around $40/each and got them at Home Depot. Have one on each floor.
   / carbon monoxide poisoning #8
Wow, surprising to hear how many people have been saved by their CO detectors or nearly killed by CO! :(
I have a few Kidde Nighthawks:
Amazon.com: Kidde KN-COPP-3 Nighthawk Plug-In Carbon Monoxide Alarm with Battery Backup and Digital Display: Home Improvement: Reviews, Prices & more
I've had others of various brands, but many were too sensitive, would give false alarms, or had problems after a year or two. This one was highly recommended by a firefighter friend who says he has never found one to give a false alarm-- not in his home or on a call for CO detector activation. So these are what I use now. :D
They run on AC power but also have a replaceable 9v battery inside in case of a power outage.
   / carbon monoxide poisoning #10
Dumb question, if you've got no power, what's going to produce the CO?
Wood burning stove. A wood fire in the "coals" stage, as it might be during an damped-down overnight burn, produces the most CO.
The propane-fired stove/oven in the kitchen can produce CO also, and with no electricity, the exhaust fan would not be running.
ALLMAND LIGHT TOWER (A58216)
ALLMAND LIGHT...
(APPROX. 25) 4' X 8' X 3/4" OSB SHEETS (A52706)
(APPROX. 25) 4' X...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
SD Lanch SDLD 25 Rubber Track Dumper (A57149)
SD Lanch SDLD 25...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A56857)
2019 Caterpillar...
