Carbide saw blade differences?
/ Carbide saw blade differences? #1
stumpfield
Sierra Foothills
2005 MT265B
I didn't see a tool section on TBN so I hope to get the answer here...
What's the differences between C2, C3 and C6 carbide saw blades? I think it's something to do with hardness but which one is harder? Is harder the better? Any pro's and con's? Thanks for you help.
/ Carbide saw blade differences? #2
Hi Stumpfield,
I think you answered your own question. I believe its the hardness of the carbide teeth. Try a search in Google. C6 being the toughest.
/ Carbide saw blade differences? #3
I might be wrong, but if you're looking at a circular saw blade that is C6, walk away. That is entirely too hard. I don't think you want anything harder than an C4 for a saw blade. If it is too hard, it will be brittle, which translates into shatter. If you're looking for a saw blade for a table saw, get the Forrest. Expensive, but worth every penny.
Oops, I wish I read this earlier. So, harder is not necessary better:eek: :eek: Just bought a whole bunch of C6 carbide circular saw blades at a closed out sale. I thought I got myself a bargain but I guess not anymore.:mad: Is it dangerous to use C6 carbibe blade to cut wood with a circular saw? Does it shatter easily? If I can't cut wood, what can it use for?
/ Carbide saw blade differences? #5
I think youll be fine.
If you dont use them for wood you can also cut non ferris metals, plastics, all kinds of stuff.
/ Carbide saw blade differences? #6
It's not dangerous, just don't be surprised to see a broken tooth every now and then. Hand saw? Those kind of blades are fine. Get a good quality blade for your table saw, though.
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
55 GALLON BARREL TOTE/ OVERHEAD CREEPER (A67714)
55 GALLON BARREL...
Shop Cart (A68134)
Shop Cart (A68134)
2015 Yamaha 350hp 4-Stroke Outboard Boat Motor (A66738)
2015 Yamaha 350hp...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
Unused 2023 Monroe Tufline TW693222 12ft. Pull Behind Disc Harrow Tractor Attachment (A66734)
Unused 2023 Monroe...
