Carbide saw blade differences?
   / Carbide saw blade differences? #1
stumpfield
Sierra Foothills
2005 MT265B
I didn't see a tool section on TBN so I hope to get the answer here...
What's the differences between C2, C3 and C6 carbide saw blades? I think it's something to do with hardness but which one is harder? Is harder the better? Any pro's and con's? Thanks for you help.
   / Carbide saw blade differences? #2
Hi Stumpfield,
I think you answered your own question. I believe its the hardness of the carbide teeth. Try a search in Google. C6 being the toughest.
   / Carbide saw blade differences? #3
I might be wrong, but if you're looking at a circular saw blade that is C6, walk away. That is entirely too hard. I don't think you want anything harder than an C4 for a saw blade. If it is too hard, it will be brittle, which translates into shatter. If you're looking for a saw blade for a table saw, get the Forrest. Expensive, but worth every penny.
Oops, I wish I read this earlier. So, harder is not necessary better:eek: :eek: Just bought a whole bunch of C6 carbide circular saw blades at a closed out sale. I thought I got myself a bargain but I guess not anymore.:mad: Is it dangerous to use C6 carbibe blade to cut wood with a circular saw? Does it shatter easily? If I can't cut wood, what can it use for?
   / Carbide saw blade differences? #5
I think youll be fine.
If you dont use them for wood you can also cut non ferris metals, plastics, all kinds of stuff.
   / Carbide saw blade differences? #6
It's not dangerous, just don't be surprised to see a broken tooth every now and then. Hand saw? Those kind of blades are fine. Get a good quality blade for your table saw, though.
(INOP) KUBOTA L2550 TRACTOR (A51247)
(INOP) KUBOTA...
CAT D6C Crawler Dozer (A47477)
CAT D6C Crawler...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
1982 GOOSENECK 24FT TRAILER (A52472)
1982 GOOSENECK...
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
