Carbide Cutter Blade Adjustment
   / Carbide Cutter Blade Adjustment #1
McCaskey
East Aurora, NY
My Carbide Cutter has an adjustable cutter blade behind the rotor. According to the manual, it should have been shipped with an 1/8" gap between the carbides & the blade. It currently has a 1/4" gap.
Does anyone have any experience on performance with more or less gap on Carbide Cutters?
The manual states the gap is dependent on the power of equipment, but doesn't have any guidelines. I'm running an RC100 with a No. 8 hydraulic motor.
   / Carbide Cutter Blade Adjustment #2
the gap setting determines the size of the material discharged...tighter the gap smaller the discharge
   / Carbide Cutter Blade Adjustment #3
Thus the more power that is required. Caskey, try decreasing the gap and see what happens. Depending on the desired final mulch you may better off to leave the gap a little as it will cut faster and you'll burn less fuel etc.
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
2016 Ford F-450 12FT Flatbed Truck (A51691)
2016 Ford F-450...
Jack Daniels Sign Decor (A51694)
Jack Daniels Sign...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53473)
2019 Krause...
2019 KENWORTH T880 HYDROVAC (A53843)
2019 KENWORTH T880...
2019 CHEETAH T/A CHASSIS TRAILER (A53843)
2019 CHEETAH T/A...
