Carbide chainsaw chains
   / Carbide chainsaw chains #51
Rakes are an important safety component of chains to reduce kick-back. I'll keep them on all the chains we have, (have more than a dozen) but will be knocking down the rakes, as called for by wear.
   / Carbide chainsaw chains #52
Where you at in Mid Michigan area, I sharpen my own chains but would like to see how you sharpen yours.
I'm close enough to I-75 and I-69 to visit just about any member in Southern lower MI at the drop of a hat, and I sharpen anything I can get my hands on. ("hard work dispels worry" Maggie to Doris) My few little tricks get very good results from the cheapest HFT sharpener by using its weakness (hardly rigid) to best advantage.
Briefly, use the flex of the machine to bring the wheel down in a j-like stroke. Hold it to the right as you come down, then wiggle it to the left as 'tap' the wheel against the tooth face. "tap, tap, tap" then hold the wheel again to the right of its 'give' so as not to contact the tooth at all on the upstroke. If failing that last bit your rake angle would match the upstroke path (sloppy if a worn or cheapo machine, so vital) vs the intended angle. Smooth contact of wheel to work was never important enough to matter.
The chains I do are for guys that buck 12" dia ash 'leaners' (post ash-borer death) with 16' saws, so 'rakers' (aka depth gages) are removed to try to teach the guys to use the saws as saws and not like grinders. Full RPM will cause the chain to skip, limit 'peel' per tooth, and cause unnecessary wear. "feeds and speeds" for all materials. ;) When ~1/3 of your chips are more like sawdust, you should have rotated to a sharp chain already.
Set up: With motor off, adjust the wheel to correct depth of the gullet. Adjust the stop so that as you rotate the wheel by hand the high spot of the 'wobble' just touches the tooth. This'll get you .010" or more peel when powered up. I use a dial caliper to monitor tooth length, so as to balance L to R height and strive for the straightest cut. I'd have posted youtube videos of just such things (machine shop tricks) but not enough folks trust the quality of pro bono work and I'm doing other chores while waiting for more work and movie production help.
I suggest a post-sharpen rinsing in kero and 'drip drying' of chains to minimize swarf (grit, detritus, etc) causing wear to the bar. If/as the wheel gets rounded on one side, just flip it over to use the sharper corner to keep rake going nearest to full gullet depth. :)
   / Carbide chainsaw chains #53
Briefly, use the flex of the machine to bring the wheel down in a j-like stroke. Hold it to the right as you come down, then wiggle it to the left as 'tap' the wheel against the tooth face. "tap, tap, tap" then hold the wheel again to the right of its 'give' so as not to contact the tooth at all on the upstroke. .....
That's the same way I use my HF sharpener. The j-stroke is a very good analogy. :thumbsup:
   / Carbide chainsaw chains #54
Thanks Old Grind.
Some good tips there. I have what I think is one of the better sharpeners from Baileys. But it does have the slop left to right as you mentioned. Never thought about holding it to the right on the up stroke (will definitely give that a try).
Interesting and welcome advice on those chain sharpening machines. Makes me want to get my el-cheapo out, set up and whirring.
   / Carbide chainsaw chains #56
When I got my chain grinder I also put a CBN wheel on it because I didn’t want to deal with half to maintain the profile of the other wheels. It’s supposed to cut cooler and with less burr than the other wheels. My grinder also had some runout on the arbor. This isn’t a good thing. It makes the wheel cut more aggressive and less smooth. It would probably lead uneven wear on the wheel. Using a dial indicator and some brass shim stock I got the runout pretty much eliminated. I also use the flexing the head into the tooth approach. But taking off 10 thousands on the down approach is too much. I set mine so the wheel barley touches the teeth and then flex it into the teeth.
   / Carbide chainsaw chains #57
.. I also use the flexing the head into the tooth approach. But taking off 10 thousands on the down approach is too much. I set mine so the wheel barely touches the teeth and then flex it into the teeth.
Absolutely, it's important to see that there is no contact on either the up or down stroke. If a 'so-so' wheel wobbles, it's then we'd barely touch the high spot with the power-off-finger-feel stop adjust & see the .0x0" peel according to the feel (my 'taps' to minimize heating) at the bottom of the J.
Guys, I may go around a chain 3-4 times per adjustment of the stop. It's done to ('spark-out') best imitate the finish that 4570Man's CBN wheel surely leaves. And yes, vs our vitreous wheels with paper 'blotters' the resin bonded wheel is indeed best trued on its spindle. (CBN 2x $ as diamond)
   / Carbide chainsaw chains #58
I checked the wheel for wobble because I was going to send it back if it was wobbling. The runout was in the grinder arbor. I thought about trading it but I didn’t figure the replacement would be any better. I know the grind results were a lot better after shimmed the wheel and got it running true. BTW cbn is for HSS and diamond is for carbide. They’re not interchangeable abrasives. I know this is the carbide chain thread but I don’t own one of those and everything in my posts is based on a regular chain.
CFG Industry MX15RX Mini Excavator (A57149)
CFG Industry...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
Volvo L306 (A57148)
Volvo L306 (A57148)
TUGGER TRAILER (A55745)
TUGGER TRAILER...
48in Forks and Frame Skid Steer Attachment (A56857)
48in Forks and...
