Oil & Fuel Carb Rebuild Kit
   / Carb Rebuild Kit #1
Bigwoods
Northern Minnesota
135 Massey Ferguson
I think I need to put a carb kit on my MF135.. I took off the carb and found an electrical wire. What is that for? Did MF use the same Zenith carbs on the Perkins 3 cyl. I think Tractor Supply has the kits. Thanks
   / Carb Rebuild Kit #2
Sounds like two problems. You stated you took off the carb and found a wire. Explain. To lookup your carb. Go to www.agcopartsbook.com Are you stating you have a 3 cylinder gas Perkins engine?
   / Carb Rebuild Kit #3
I'm going to guess the wire goes to a fuel shut-off solenoid for the main jet. When energized the solenoid pulls a needle back and allows fuel to flow through the main jet. If the solenoid stops working it doesn't allow fuel to flow so guys normally remove them and put a small 1/8th inch plug in it's place. My Freguson has a 4-cylinder Perkins, this is the carb after I rebuilt it. I found a float for it on ebay just by looking at a picture.
   / Carb Rebuild Kit
Mine is a 3 cyl. gas Perkins. The fuel shut off explanations sounds right. I just couldn't figure out why it was there. I will get a carb kit but was just wondering if the same carb was used on most models. TSC is 25 miles away and wanted to get the right thing.
   / Carb Rebuild Kit #5
My advice is not to throw any of the old carburetor parts away. If your old carb was made in the US, the old parts may still be better than new Chinese parts. Chinese gaskets seem to be ok, but the float needle and seat assemblies tend to be junk, and the fuel shutoff/sediment bowls made in China are often so bad that they have no use , except as a paper weight. If you can find new old stock parts online, grab them !
1996 INTERNATIONAL 4700 4X2 DUMP TRUCK (A51406)
1996 INTERNATIONAL...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A51692)
2015 Freightliner...
2017 Wanco WSDT Towable Compact Radar-Speed Trailer (A52377)
2017 Wanco WSDT...
1985 International 1754 Material Spreader Dump Truck (A51691)
1985 International...
2016 Dodge Caravan (A51694)
2016 Dodge Caravan...
2014 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2014 Great Dane...
