Carb Cleaner
/ Carb Cleaner #1
mjarrels
Elite Member
Virginia
1949 farmall, 1961 Fordson Dexta, 1986 Duetz Allis, 2001 Kubota.
Can you use carb cleaner instead of starting fluid to start a cold diesel engine... my ford tractor needs a boost when it is really cold. Been using a small shot of starting fluid but I know it is dangerious for the engine. Thanks.
mark
/ Carb Cleaner #2
Wouldn't it be easier to install a ether system or a block heater? Carb cleaner would probably work but it's flash point is probably higher than alone.
/ Carb Cleaner #4
Your kidding right? Brake cleaner?
/ Carb Cleaner #5
There are a lot of sprays that would work. Many spray cans can be found in most garages that say flammable could substitute for ether. Even WD-40, Though I am not advising the use of any of them. I would agree to get a block or in line lower hose type heater if you are having cold start problems.
/ Carb Cleaner #6
Read it in the "tips" thread from a GM mechanic. About the most recent post.
/ Carb Cleaner #7
Doesn't really matter if it's a GM mechanic who gave the tip. I was a GM medium duty truck mechanic and I have never heard of anything so silly. Brake cleaner as a starting fluid has got to be one of the funnier ones. Many of today's modern brake cleaners are not even flamable.
/ Carb Cleaner #8
I've used wd-40 to start and temp run for a few seconds a 353 with a bad fuel pump... probably safer than ether..
soundguy
/ Carb Cleaner #9
I use brake clean from Firsr Aid in the red and black can and it works as good as any starting fluid. This is the most flameble stuff I have seen.
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2017 Ford F-150...
2012 Ford F-250 4x4 Pickup Truck (A60352)
2012 Ford F-250...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A59230)
2017 Freightliner...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2004 PSI M413XT Maintainer Motor Grader (A59228)
2004 PSI M413XT...
