Carb adjustment on JD 322 Lawn Tractor
   / Carb adjustment on JD 322 Lawn Tractor #1
Tomcat60
Wyoming, Illinois
John Deere 322 Lawn Tractor
I have a 1986 John Deere 322 lawn tractor with 436 hours. The tractor sat for 3 years. I have cleaned out the carb, gas lines, tank pump, and replaced the filter. It fires right up but I'm not sure on the adjustment to the carb. It runs but the rpm ocsillates when at high rpm. ALso seems like the governor sticks and when I throttle up I have to flick it loose to get the motor to rev? Can anyone tell me what the adjustment screw on the side of the carb should be? Also, how can I keep the governor from sticking?
   / Carb adjustment on JD 322 Lawn Tractor #2
I am not sure about the settings but you might have sediment or varnish in the carburetor. On mine the fuel shutoff solenoid needs to be replaced and maybe other parts as well because the throttle or governor sticks as well. If you know of a place to get parts I would appreciate it.
Best
Chris
   / Carb adjustment on JD 322 Lawn Tractor #3
The adjustment is in the service manual and it depends on which version of the 322 you have. On my 322 when it was surging I had a leak at the welch plug. I can email you the service manual if you can get me an address. I have the earlier version and have been very happy with it but use it a lot. It is a working tractor, snow in the winter and mowing and lawn work in the summer.
2015 CHEVROLET SILVERADO 3500HD CC (A55745)
2015 CHEVROLET...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2006 STERLING CONCRETE MIXER (A55745)
2006 STERLING...
2006 FORD E-350 SUPER DUTY SERVICE VAN (A52706)
2006 FORD E-350...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50322)
2015 Big Tex 70PI...
2025 Heavy Duty Wheel Balancer (A55788)
2025 Heavy Duty...
