Carb adjust question
   / Carb adjust question #1
jeff pk
OR
1960 Ford 641 1957 Ford 860
After a rebuild to a big M/S in a 1959 881, the IT manual says: "To adjust the main adjusting needle, bring engine up to operating temp, remove any three spark plug wires, open the throttle to full throttle setting and adjust the main needle until highest operating rpm is attained. Turn the needle clockwise until the engine speed just begins to drop, then turn cc just enough to bring the engine speed back to top rpm."
Is that really possible---to remove 3 S.P. wires and run it to max rpm's? The last bit makes sense, but I don't believe my tractor will run with 3 S.P. wires removed...
   / Carb adjust question #2
re-read what you typed.
you didn't say to run at max rpm on 1 wire. it said to adjust till you hit a spot rpm no longer climbs with more adjustment.
will it run? probably. .. I see plenty start on 2 all day.
would i do it. naa.
i start them at about 1.5-2 turns out.
then see if it takes throttle without stumbling.. but not so much that it makes black smoke...
2021 Nissan Altima Sedan (A51694)
2021 Nissan Altima...
2005 Wells Cargo CEW202 20ft T/A Enclosed Concession Trailer (A51694)
2005 Wells Cargo...
2008 Chevrolet Impala Sedan (A51694)
2008 Chevrolet...
2007 Freightliner Columbia 120 - Class 8, 6x4, Mercedes MBE4000 Diesel (A52748)
2007 Freightliner...
1270 (A50490)
1270 (A50490)
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
