Carb adjust question
   / Carb adjust question #1
jeff pk
OR
1960 Ford 641 1957 Ford 860
After a rebuild to a big M/S in a 1959 881, the IT manual says: "To adjust the main adjusting needle, bring engine up to operating temp, remove any three spark plug wires, open the throttle to full throttle setting and adjust the main needle until highest operating rpm is attained. Turn the needle clockwise until the engine speed just begins to drop, then turn cc just enough to bring the engine speed back to top rpm."
Is that really possible---to remove 3 S.P. wires and run it to max rpm's? The last bit makes sense, but I don't believe my tractor will run with 3 S.P. wires removed...
   / Carb adjust question #2
re-read what you typed.
you didn't say to run at max rpm on 1 wire. it said to adjust till you hit a spot rpm no longer climbs with more adjustment.
will it run? probably. .. I see plenty start on 2 all day.
would i do it. naa.
i start them at about 1.5-2 turns out.
then see if it takes throttle without stumbling.. but not so much that it makes black smoke...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2007 National RV Dolphin 35FT Class A Motorhome (A51694)
2007 National RV...
2024 JOHN DEERE 8R 280 LOT NUMBER 7 (A53084)
2024 JOHN DEERE 8R...
STORAGE FEES (A54313)
