Car Brake Rotor Replacement / Resurfacing
   / Car Brake Rotor Replacement / Resurfacing #31
No, no. Don't grind anything. You need to use a C clamp and squish the piston back into the caliper. Or, use giant sized channel locks.
edit: Yeah, what Bird said!! He types faster.
And you don't want to forget to open the brake fluid reservoir, and maybe even take some fluid out so you can push the fluid back with the piston without running the reservoir over.
   / Car Brake Rotor Replacement / Resurfacing #32
open the caliber bleeder and take the pressure off right there. You should not push fluid back into the master. It's done all the time, but not recommended.
When you are done, you should bleed anyhow. Personally prefer the gravity bleed method for driveway brake jobs. Virtually guarantees no air.
   / Car Brake Rotor Replacement / Resurfacing #33
I don't think I'm explaining the problem right. The pads have a notch at the top and bottom. These notches ride on metal clips that go over the metal brake assembly. I need to grind the assembly that these clips go over. Right now the pads are very tight. I've done lots of brakes, never had one go on so tight, to where it won't slide out any after the brakes are released, so the pad is always tight against the rotor. Not only does it eat brake pads and rotors, but it also kills gas mileage.
I use the C clamp method for pushing the calipers back in, with brake cap removed. Been doing it this way for many years.
   / Car Brake Rotor Replacement / Resurfacing #34
What dodge are you working on exactly? What part # are you getting?
   / Car Brake Rotor Replacement / Resurfacing #35
This is a 2001, 1500 Quad cab dodge ram 4x4.
I bought OEM brakes and rotors this time from NAPA.
This has been a problem since I bought the truck, just the one wheel. I think the original caliper part that holds the pads is a little out of spec.
   / Car Brake Rotor Replacement / Resurfacing #36
Well, that's something new to me.
Anytime I grind or hammer something, it occurs to me a millisecond later why it wouldn't go together in the first place. :eek:
   / Car Brake Rotor Replacement / Resurfacing #38
:DThat's certainly familiar. I've done that, more than once.:D:D
   / Car Brake Rotor Replacement / Resurfacing #39
Is it rusted and you are going to lightly clean up the surfaces"
Are the new pads physically the same dimension on the backing plate?
   / Car Brake Rotor Replacement / Resurfacing #40
It's possible the bracket is out of spec or bent.
Measure it out on the "good" side of the truck.
The reason I asked is a few years of late 90's early 00's GMs have
a different set of brakes that's thinner than the rest. Some year
Dodges take the same pads as GMs. I was hoping for a mix up somehow... :)
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
2016 New Holland Boomer 47 4WD 45HP Loader Utility Tractor with Bush Hog BH16-2 (A55787)
2016 New Holland...
1969 Lincoln Continental Mark III (A55758)
1969 Lincoln...
1983 Case 580D (A47477)
1983 Case 580D...
UNUSED (1) 3500# IDLER DROP AXLE (A54756)
UNUSED (1) 3500#...
2016 Hyundai Tucson (A55758)
2016 Hyundai...
