Caps for the bucket curl cylinder .
   / Caps for the bucket curl cylinder . #1
NIXON
West Sunbury ,Pa.
L3130 hst
I've developed a small leak in one of my bucket cylinders . It's a 513 loader . What size are the caps I need to use to seal of the system while the cylinder is off the loader ?
Thanks , John
   / Caps for the bucket curl cylinder . #2
I've had my bucket curl cylinder off twice. Once to change the o-rings and then once to replace with a new cylinder(warrantee). I didn't use caps. I put a plastic bag with a rubber band around it to keep dust out. Of coarse I wasn't using the tractor while I was doing this. If you are going to have your hydraulics active during the time you have it off then I would cap them.
Steve , Thanks for the response . No, I won't be using it during the time the cylinder is off . So the bag Idea sounds great . John
   / Caps for the bucket curl cylinder . #4
John,
Is your cylinder still under warantee? Where is the leak coming from on the cylinder?
Steve , not according to the dealer . But then things do break . So. I'll be out about $150.00 or so for the rebiuld . It's leaking a few drips per minute from the end closest to the loader . It leaks during curl . Most likely something got past the wiper seal and into the O ring packing . John
   / Caps for the bucket curl cylinder . #6
If it is out of warranty, look for a independent cylinder repair shop. Usually they do repairs just as well, in half the time and money. Unlike the dealer, that is all they do, so they know all the tricks of getting it done faster and usually better. They will have all the necessary seals to do the repair and the replacements might be of better quality than the OEM seals..... Just mention to them that you don't want it painted. Many paint the cylinders after they are repaired as part of the service... Junk....
   / Caps for the bucket curl cylinder . #7
John why not ask the dealer what size the caps are?
Junkman , I'll look into that. Thanks ! John
Frank ,I did! Her suggested that I just come down and get a bunch of caps . I guess it was up to me to find the right ones .
Kind of took the luster of my confidence in them about the repair /forums/images/graemlins/smile.gif
But then ,I was talking to them sales side of the house ,not the service side . John
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
2010 FORD F-150 (A53843)
2010 FORD F-150...
DRAGON 500 BBL FRAC TANK (A53843)
DRAGON 500 BBL...
VERMEER RTX130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX130...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
