Capacity for loading R4 tires on a 2520
   / Capacity for loading R4 tires on a 2520 #1
Landon
Greene, Iowa
Kubota L175 and John Deere 2520
I just loaded the R4 tires with windsheild washer fluid on my 2520 last night and thought that I would post some capacities. I couldn't seem to find this info while searcheing the other day, and the charts that one chart that I looked at was off by a long shot. The rear wheels held 25 gallons each and the front wheels held 5.5 gallons each. I filled them just over the top of the rim. I used the drill pump method with it hooked to my drill press. It took me about 4 hours from start to finish to get it done. Now for the fun part, seeing how much more traction I have.
   / Capacity for loading R4 tires on a 2520 #2
Thanks for the info. What is the tire size on the 2520?
Should get you about 400 lbs on the rear, but I still have a ballast box in addition to the fluid to counter weight on the FEL.
You did add the lower temp WW fluid - - right? :)
2013 FREIGHTLINER EXT CAB SERVICE TRUCK (A51406)
2013 FREIGHTLINER...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2015 Ford Explorer SUV (A51694)
2015 Ford Explorer...
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
2021 CATERPILLAR 289D3 SKID STEER (A51246)
2021 CATERPILLAR...
JOHN DEERE 5075E (A53084)
JOHN DEERE 5075E...
