5030tinkerer
I have a Harbor Freight pancake compressor with about 10 hours of use on it (although it is a year or so old). Plugging it in the other day resulted in smoke spewing from it after a few minutes of running. Taking the plastic cover off revealed a small hole in the base of the about 3.5" long x 1.25" diameter 250V 65 microfarad motor run capacitor.
The cap was warm to the touch and the smoke was coming from here. The manufacturer intended the cap to be held to the frame of the compressor using the integrated 5/16" or so stud coming from the base of this cap, but the locknut and nut were nowhere to be found. Likely the thing just vibrated itself to death, but as long as I get to replace this thing anyway, is there some benefit to going with a larger capacity capacitor, perhaps 100 microfarads or even higher? Does anyone have any good online sources for capacitors?
