Can't start my JD 2520
   / Can't start my JD 2520 #1
Piedmont
NC, USA
JD 2520
I just finished mowing (about 4 hours) pulled the tractor in front of the barn to let it cool off. A couple hours later I went to start and it would not crank. I will do my best to describe what I'm hearing. When I turn the key it makes a loud sharp scraping sound. The sound seems to be coming from the left went sitting in the drivers seat. Would the starter just stop working like that or might it be something else. Appreciate any help you can send my way it's a JD 2520.
   / Can't start my JD 2520 #2
1st thing to do is double check to be sure trans & pto are in neutral. Then check battery voltage with a volt meter. Then remove,clean & tighten all 4 battery cable connections.
   / Can't start my JD 2520 #3
Sounds like the gear is stuck in the open postion. I have had this happen on other machines. Give a sharp blow to the side of the starter with a wrench or a rubber mallet. I usually just use a heavy wrench. Give it a good blow and then try to start. Should catch and start.
   / Can't start my JD 2520 #4
when all else fails, use a :hammer:
I did all the above and change. I saw the suggestion about hitting the starter with a wrench if it were to work it sounds like a temporary fix. Thank you for the fed back.
   / Can't start my JD 2520 #6
Not necessarily a temp fix. Sometimes it will free up and not give any more problems. If it does do it again, it's time for a new starter
   / Can't start my JD 2520 #7
yup...I've done many of starters like that Mike.....have someone try to start it while im out under the hood tapping on the starter with a hammer ......It usually worked no problem.....
As soon as I get back from church, I'm going to give it a try. I'll let you know how I make out. Thanks again.
Unfortunately that didn't work. I hit it closer to the mounting bolts a couple of three good wacks nothing.
   / Can't start my JD 2520 #10
Piedmont, Have you looked into the battery? Same situation on my 2520 last summer. Mowed, went in for lunch and would not even turn over when I came back. The battery operated the fuel pump (clicking sound when key is on) and also operated headlights. However, wouldn't crank machine. Took the battery in for a load test and it was toast. 1 new battery and I have not heard from it since. I would try that.
Ford NAA Jubilee Tractor (A52748)
Ford NAA Jubilee...
2011 JCB 515-40 Telehandler (RUNS) (A50774)
2011 JCB 515-40...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2014 Dodge Ram 5500 4x4 Bucket Truck with Altec AT40M - 45FT Boom, Jib Winch and Utility Bed (A52748)
2014 Dodge Ram...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
