Can't shift case intenational 485 while moving using clutch?
   / Can't shift case intenational 485 while moving using clutch? #11
Standard tractor operating procedure is to fully stop before making clutch-and-gear, gear changes.
And the 485 (like its smaller sibling the 385) should have a synchronized transmission, a power shift transmission, or a power shuttle transmission.
If it has the 8 speed "Syncromesh" transmission (with shifts within forward ranges synchronized), you should only need to stop for a High/Low shift.
hayesy, how many speeds does your transmission have? Does it have a shuttle to choose foward/reverse?
Aaron Z
SARLO MOWER (A55758)
2024 LS MT242E MFWD Compact Utility Tractor with LL3003 Front Loader (A55302)
2024 LS MT242E...
2013 Dodge Charger Sedan (A55973)
2013 Dodge Charger...
KBH 25 TON TENDER (A56435)
KBH 25 TON TENDER...
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2020 FREIGHTLINER...
2023 Chevrolet Tahoe SUV (A56859)
2023 Chevrolet...
