can't see my bx1850 tachometer,should i add another/
   / can't see my bx1850 tachometer,should i add another/ #1
shrekbelly
friends and esteemed forum contributors,
on a good day with the right amount of food and sleep, i might soar to the towering height of 5 ft 7 inches tall, with my namesake belly, seeing my tractor's tachometer is an impossibility.
i'd like to know engine rpm for running the mmm as efficeintly (sp) as possible . . . as well as getting it right for rear pto use (my tilller will be forthcoming).
i suppose, i could always try to semi stand to get a glimpse of the tach . . . or purchase a tiny tach and mount it somewhere more visable.
as a kubota greenhorn, rookie, rube, grasshopper my learning curve, is a big one . . . i admit to not knowning a whole lot.
has anyone thought about this one? oh, BTW, i don't want to sit on phone books or pampers packages. thanks in advance for your replies- robert a.
a.k/a shrekbelly
   / can't see my bx1850 tachometer,should i add another/ #2
FWIW, the earlier model BX's didn't have a tach. We've all learned to efficently operate our machines by the proverbial seat of our pants :D
This may re-start the non-ending debate of what engine rpm is the best for all the differing jobs these machines will do and I adjust my rpm accordingly.
For finish mowing, I set the throttle lever at approx 3 o'clock which is about a hair back from WOT, I've found that this works best for me which = best finish cut.
High blade tip speed is the key to a great finish cut (ala commercial mowers) and to achieve high blade tip speeds one needs high engine rpm.
For BH work I also run at about the same rpm as finish mowing as I want all the speed and power I can get out of my BX23
For general transporting I can vary anywhere from 2 o clock to 3 oclock, generally staying on the low side of needed rpm's without lugging the engine.
In any case, do whatcha gotta do :D
volfandt,
starting an unending debate debate was not my aim. your suggestion, noting the throttle arm position is a simple/great idea.
i'll search thru the archives to review past postings and debates.
thanks, shrekbelly
p.s. senior in age, bx rookie, true orange believer!
   / can't see my bx1850 tachometer,should i add another/ #4
shrekbelly said:
volfandt,
thanks, shrekbelly
I agree with Volfandt. I seldom look at the tach. Snowblower runs best with the lever pulled down tight and the mower at the 3:00 position is about 3000 on the tach. It does not take long to learn a machine and where it needs to run.
   / can't see my bx1850 tachometer,should i add another/ #5
I have a B7100 HST that did not have a factory tach and much like you would like to see what the engine speed was to run the tractor at optimum power rating, in a web search I found that all the ratings, PTO speed, peak hp etc was at 2800 rpm. I have added a Tiny Tach and noticed that the mower does much better at the rated rpm, like was said in previous posts, after a bit of seat time you will get the feel of when you are lugging the engine. I have used Tiny Tach's on my small engines for years and with the diesel it's great for service reminders.
   / can't see my bx1850 tachometer,should i add another/ #6
I don't care to much for digital tachs I would rather have a anolog tachometer any time. I wish the hour meter and tach was seperate on my 2350 or at least be able to switch back an forth with the motor running.
i know you genltemen are correct about not needing or having the tach, and that ultimately, i'll get used to the engine sounds . . . part of me is always looking for a way to re-invent things my way.
i'll figure out a way to mark throttle positions for the mmm and rear pto.
thanks --- shrekbelly
   / can't see my bx1850 tachometer,should i add another/ #8
I know, get a B2320........ big tach!
2012 RAM 5500 (A52472)
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52577)
2013 UTILITY VS2RA...
2019 Nissan Sentra SV Sedan (A51694)
2019 Nissan Sentra...
91013 (A48082)
91013 (A48082)
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
