Loader Can't pull a fence post
   / Can't pull a fence post #11
As the load on a 3pt hitch moves back, the whole tractor works as a lever, with the fulcrum at the rear wheels. While you don't get lots of reduction of lift capacity, you will more rapidly get a light front end.
Bruce
That is why I suggested to fill the bucket is it is needed. I took out those 6 inch post , buried 3 feet in the fall with ground not real dry. I had 3 suitcase weight each about 60 lbs or so. My front lifted up some but little bit at time pulled the post buried for more than 40 years.
JC,
   / Can't pull a fence post #13
I'll try rocking them first - I just don't want to break off any.
There is no concrete here, just set in 3-4'.
David
Just a small amount of back and forth motion is usually all you need to loosen them up. If that doesn't work, try digging around them with a shovel and fill the trench with water and keep it wet for a day or so and then pull them.
   / Can't pull a fence post #14
When I've came across a post that wouldn't pull, I lay a thick block beside the post, lay another post like a lever on the block and chain the end of it to the bottom of the stuck post and press down on the high end of the lever post with the FEL. Even with my tiny tractor I'm sure to be able to get at least 4000# (probably a good deal more) of lift levering the weight in such a way.
So I tried rocking one and pulling it. Broke right off at the ground.
I don't have a 3pt lift attachment and this doesn't justify buying one.
I guess I'll have to get things wet.
   / Can't pull a fence post #16
A minimum attachment would be a drawbar:
CountyLine® Cross Drawbar, Category 1, 3/4 in. dia. - Tractor Supply Online Store
or a lever:
Rocking Seven Mile Ranch: Ranch Work and Calving
or hire a caber picker:
Bruce
   / Can't pull a fence post #17
It is amazing how tight a 6" post can be. You might not get them out with breaking them off as you will have to rock them a little to loosen them up. If you are able, route your chain so you can use the bucket curl along with lift to get the greatest pulling force. Since your bucket hooks are on the corners of the bucket, be sure to connect the chain to both hooks so it pulls evenly on both corners or you could bend your loader cross members. I have pulled pipe post set in 8" of concrete with my DX45 (essentially the same as your tractor) using this technique.
I recently pulled some 2.5" pipe post for a friend that were in dry ground close to 4' without any concrete. Some pulled right out, others lifted the rear of my L39 with loaded tires and the backhoe on. Got them all out by rocking them some.
   / Can't pull a fence post #18
If you have room, put your bucket over the post so that the post is now behind the bucket. Place the bucket flat on the ground. Route your chain over the top of the bucket and down to the bottom of the post, wrapping it good around the post so it won't slip. Now, rotate your bucket toward dump while lifting up on the FEL at the same time. The back side of the bucket is nearly even with your lift pins, so you'll have maximum lift plus rolling the bucket down will assist the lift arms. I don't suggest pulling the post all the way out with this method, but just get it lift a foot or so and then remove the bucket and lift from the front as you originally were. If you can't get it from behind the bucket, then you'll probably have to use the 3PH where you have more lift than the FEL.
Nobody can say your TC45DA is or is not working properly because a post can be really tough to pull. However, out at the bucket cutting edge, you don't have nearly the lift that you can create if you are in line with the lift arm pins or even behind them a bit. You should have plenty of room between your torque tube on the loader arms and the back of the bucket or QA plate adapter.
   / Can't pull a fence post #19
   / Can't pull a fence post #20
I have an attachment made of 3x3x.25 tubing that attaches to my 3 point hitch. More complicated than a drawbar but I attach a chain to that frame of 3x3 and loop it around the fence post. Sometimes I have to rock the post to loosen it up. I do try these tasks after a good week of soaking rains. The loader never works for me unless termites and rot have helped eat away at the buried part of the post.
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2000 GMC C7500 ANCHOR DRILLING TRUCK (A58214)
2000 GMC C7500...
2005 Isuzu NQR 4 door box truck with folding gate (A56435)
2005 Isuzu NQR 4...
Cat Mixer RM-250C (A55973)
Cat Mixer RM-250C...
2015 Honda Accord Sedan (A56859)
2015 Honda Accord...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
