Rotary Cutter Can't lift my rotary cutter much.
   / Can't lift my rotary cutter much. #1
Rusty4242
Western Mass.
Kubota BX23
I picked up an older Howse 400 4 foot rotary cutter for my BX23. Fits on ok, but I had to raise the lift arms a lot to hitch onto the pins and the top link is as short as it can go. This only allows me to bring it up about level with the rear wheel, which is fine for cutting but I'd like to be able to pick it up, beaver tail style, to travel with as well as being back up on big brush. Can this be done with a brush hog and if it can, should lowering the hitch pins do it?
   / Can't lift my rotary cutter much. #2
on my tractor i had to lower the hitch pins on the mower AND adjust the 3pt arms one hole up to finally get decent amount of clearance at the wheel.
Brian
   / Can't lift my rotary cutter much. #3
Yep, some of the smaller size implements will have two sets of holes for the pins that your side links attach to. If yours does, they probably should be in the lower set of holes. I had a 4ft landpride bush hog that had two sets of holes on it but I never did need to use them for the JD 750 it was behind.
   / Can't lift my rotary cutter much. #4
Yes, lower the pins, but also consider purchasing a shorter top link.
   / Can't lift my rotary cutter much. #5
Dropped the pins about 4" on a King Kutter 4' mower for it to work with a BX22. Didn't need to change the top link.
   / Can't lift my rotary cutter much. #6
Replacing the top arm with a short length of chain also works well with a cutter. Allows the deck to float on the rear wheel much easier without binding when going through a dip.
And as said, lower the lift pins on the cutter to match the 3 ph arms.
I didn't understand what "level with the rear wheel" meant. :confused:
   / Can't lift my rotary cutter much. #7
Get a short BX hydraulic toplink and you will lift the back wheel off the ground.
   / Can't lift my rotary cutter much. #8
CCI
That certainly is the best option. No one should be without one. :D
Life is too short.
2021 JOHN DEERE 8R250 LOT NUMBER 193 (A53084)
2021 JOHN DEERE...
(1) HD 24ft Free Standing Corral Panel (A51572)
(1) HD 24ft Free...
New/Unused AGT Industrial SDA-140T Track Loader (A51573)
New/Unused AGT...
Mohawk 12,000lb Two-Post Electric Auto Lift (A51691)
Mohawk 12,000lb...
2008 Volvo XC90 SUV (A51694)
2008 Volvo XC90...
MASSEY FERGUSON 492 TRACTOR (A51406)
MASSEY FERGUSON...
