Can't identify a pump
/ Can't identify a pump #1
Ed Love
I have a BorgWarner hyd pump with S15S4AH71L stamped in the aluminum housing. The inlet and outlets are 3/4" pipe thread. Does anyone know the specs of this pump?
Thanks, Ed
/ Can't identify a pump #2
I have read that you can calculate the pump because I had a hydraulic motor that I meaured. As I remember you measure the gear x the width and then the RPM will give the volume. There might be something else but if you find the correct site you will be close.
Craig Clayton
J.J. thanks for the info. I've looked at the site and it appears it's intended to calculate HP of a pump or HP needed in a motor based on known info. i.e. flow, pressure. These are the things I don't know.
Thanks, Ed
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
1995 Ford LT9000 Tri-Axle Dump Truck (A64556)
1995 Ford LT9000...
2019 Chevrolet Express 2500 Cargo Van (A64556)
2019 Chevrolet...
2017 TAKEUCHI TL8 SKID STEER (A65053)
2017 TAKEUCHI TL8...
2022 EZ-GO ELITE...
