Can't get the L3130 to go forward OR backwards!
   / Can't get the L3130 to go forward OR backwards!
I just filled the rear tires last week too.
   / Can't get the L3130 to go forward OR backwards! #12
Mike058 said:
Stupid newbie question here. In this situation, does having the box blade on the back help or hinder? I know extra weight should provide more traction, but hasn't that boat already sailed? I mean, that mud looks like a wonderful lubricant and the amount of weight from the BB isn't going to help. Would removing extra weight make it easier to get the tires out of the mud? Or would it make any difference? Just curious.
my guess is that in this situation you are just plain screwed :p with the frame in the muck, BB and FEL are just for looks. Time for a winch or a neighbor with a big JD. ;)
   / Can't get the L3130 to go forward OR backwards! #13
Geedub,
Sandy soil, no vegetation yet, water everywhere, everthing falling apart:eek: . Been there...done that! My question is, did YOU get stuck getting off that tractor?
   / Can't get the L3130 to go forward OR backwards! #14
If you cannot get someone to pull you out: Get 2 logs about 6-8 inches in diameter, and about 1-2 foot longer than the diameter of your tire.
With chain or strong ratchet straps, fasten them (one to each tire) in an "\" pattern across the outside diameter of each rear tire, and then in lowest gear, slowly move backwards. The "stilts" will catch and move you out.
Slow is the word, and anchor the straps/chains through the wheel slots.
   / Can't get the L3130 to go forward OR backwards! #15
You can also lay the logs under the loader to to give you some push ability. They may have to be moved a time or two.
Usually in extreme conditions of mud like you were working in more weight is a hindrance. Larger diameter tires are a blessing!:D
   / Can't get the L3130 to go forward OR backwards! #16
A come along or winch looks like your best bet since it is sloppy everywhere and a bigger tractor may just slip in the muck.
   / Can't get the L3130 to go forward OR backwards! #17
Here's a video showing what RFB is describing..YouTube - Fordson tractor stuck in the mud
   / Can't get the L3130 to go forward OR backwards! #18
Can't move forward or backward, eh? Looks like it can still move a bit.....down!~!
jb
   / Can't get the L3130 to go forward OR backwards! #20
Are there any trees close to being inline at the rear that you could attach a chain to? I was thinking of a come-along, though I'll bet that boxblade will need to come off. Maybe that could be skidded out on some 2x lumber.
2012 Ford F-250 Ext. Cab Omaha Service Truck (A50323)
2012 Ford F-250...
1990 Ford F800 7 Yd. S/A Dump Truck (A48081)
1990 Ford F800 7...
Champion C80 B (A50322)
Champion C80 B...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2023 JOHN DEERE 30G EXCAVATOR (A51242)
2023 JOHN DEERE...
2021 ASV POSI-TRACK RT-120 FORESTRY SKID STEER (A51242)
2021 ASV...
