Mowing Can't get Rotary Cutter blade off...
   / Can't get Rotary Cutter blade off... #31
It may seem counter intuitive but for stuck fasteners, I try tightening it just a bit first, then leftie loosie. Sometimes (usually) it works.
Another old trick to loosen stuck nuts is to heat the threads then rub a candle around the threads so that the wax melts around and into the threads.
Both methods have worked for me in the past but I've never tried on the rotary cutter, yet.
Years ago, I had an old VW bug and to get the rear axle nut off, we had to use a long extension pipe slipped over a Craftsman 3/4" breaker bar. After jumping on the bar the nuts would finally come loose. But one time I actually broke the Craftsman 3/4 breaker bar. They were some kinda confused when little skinny me brought that bar in for warranty replacement!
John Deere 1025R (A53317)
John Deere 1025R...
8' X 42" X 10' PALLET RACKING (A58374)
8' X 42" X 10'...
2012 CAT 316EL (A55272)
2012 CAT 316EL...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
1R PLOW, 3PT (A52708)
PALLET OF MISC (A58374)
PALLET OF MISC...
