Cant get fluid into tires? Help!
   / Cant get fluid into tires? Help! #1
wrobin
Statesville, NC
Tashan / kama
So, I have 55 gallon drum of Winter Washer Fluid, the Tractor Supply hose / valve fitting and 10' of clear hose. I even have a hand cranked drum pump. I jacked up the tractor (started with front tires to make sure I knew what I was doing). Let the air out of the tire, removed the stem core and jacked up the tire, turned it so the stem was at 2 o'clock. Drum is up in the bed of pickup truck. I get leaks and drips at the TSC attachement, but no sign the fluid going into the tire at all -when I try and pump it in, it builds pressure and either squirts all over or shows no sign of movement in the hose. What in the world am I doing wrong? Thanks! Bill
   / Cant get fluid into tires? Help! #2
   / Cant get fluid into tires? Help! #4
I put 94 gallons into the rears on a Massey 235 I owned. Used the same tools as you, except I purchased a cheap electric fountain pump. About every 4-5 gallons, I'd unplug the pump, and excess air pressure that built up would backflow into the pail I was using. After the bubbles subsided, I simply plugged it back in. It still takes a while, as the pump is fighting the whole time.
My .02.
Lunk
Thanks, I bought a transfer pump, now I need to buy the time to get it done!
   / Cant get fluid into tires? Help! #6
I used a drill powered pump around $10.00. also the fitting I sede that connected the hose from the pump to the tire has a push button on the side to relieve pressure. pump for a few seconds and then relieve pressure, repete. A tiny tire is going to build up pressure way quicker than a large rear tire.
Start with the rear first.
Auger Conveyor (A50121)
Auger Conveyor...
Unused 2025 CFG MY50R Mini Excavator (A50322)
Unused 2025 CFG...
2017 Terex Warrior 1800 PowerScreen (A50322)
2017 Terex Warrior...
2002 Chevrolet 3500 (A50120)
2002 Chevrolet...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
Mahindra Off-Road Buggy (A50121)
Mahindra Off-Road...
