Can't get er to start
   / Can't get er to start #1
851 roger
Wheatland, Oklahoma
Ford 851 Powermaster
I have an Ford 851 powermaster. Went out to start it and no spark. I pulled the cap and rotor bug and there is no spark at the points when it's turned on and cranking over. All the wires are connected. It ran several months back when I need to move some snow. A little help would be good cause I really don't want to go back in the house!!!!
I don't know the process to check it. I do know what and where it is though.
Ok I have 12 volts with the key on through the coil, into the distributer, and to the moving side of the points. I first pulled the coil wire and held it by ground while cranking and have spark there.
   / Can't get er to start #6
What was the problem..??
   / Can't get er to start #7
most likely, dirty, oxidized points.
your post saying you had power to the moving arm of the points means the coil primary was intack. the only thing left in the path is, well, ground. and that's the fixed arm of the points. it's literally chassis ground.
points probably coroded since last use, and just the act of dinking with them knocked it off.
take a piece of coarse paper and pull it thru the closed points to clean them. if you use white typing paper. it may leave a streak. that streak is stuff that was on the points.
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A54607)
2013 PETERBILT 386...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2011 DODGE CARAVAN (INOPERABLE) (A53843)
2011 DODGE CARAVAN...
2019 JOHN DEERE 325G SKID STEER (A52706)
2019 JOHN DEERE...
2016 INTERNATIONAL LF687 (A53843)
2016 INTERNATIONAL...
