Can't get bucket loader to reattach on 2210
   / Can't get bucket loader to reattach on 2210
Re: Can\'t get bucket loader to reattach on 2210
the smaller one, i believe it is 49", the 210 loader. and turf tires. I have a belly mower 62" and a rear scraper blade.
   / Can't get bucket loader to reattach on 2210 #42
Buckie,
That makes me feel a bit better; the 53" in certain circumstances can push the envelope with the 2210. I think loading the tires with RimGuard (just had it done for $118) and the ballast box are the way to go. Should be plenty for the 49" bucket. /forums/images/graemlins/tongue.gif
   / Can't get bucket loader to reattach on 2210 #43
Buckie,
I think your on the right track with the balast box. I too put mine on a dolly and store in my garage when not using it. It works great. For weight in mine, I bought bags of playground sand. They are 40 lbs each (I think) and you can adjust 1 bag at a time. I use 6 bags and have 2 extras in case I needed them.
I also have wheel weights, but can tell you it's light in the rear with only rear wheel weights so I wouldn't do any loader work without the ballast box or an implement.
Good luck and enjoy your new green monster /forums/images/graemlins/smile.gif
   / Can't get bucket loader to reattach on 2210 #44
I used 22 each 12"? square patio blocks at around 18 lbs apiece to give ~ 400 lbs in the ballast box for my X585- works well and allows you to add/ subtract weights as neccessary.
   / Can't get bucket loader to reattach on 2210 #45
I sympathize. I had this problem when I first got mine. It seemed like the front part of the frame wasn't centering itself and binding somehow. Sometimes I use the hydraulic to lift the tractor and then it popped in, not always. It was on a flat level surface BUT I was lifting the arms too high when I detached the loader then when I went to attach it the whole thing would slide around as I lowered it so then I'd have to back out unhook and realign the tractor and try again. I learned to NEVER ever lift the frame any higher than absolutely necesary to back the tractor out of it. It doesn't happen not that I've done it a few times, the suggestion about the paint might have some merit.
you are absolutely right about not raising the arms any higher than necessary. the FEL dances around like it is doing the hokie-pokie when I re-attach the hoses and start centering up for re-attaching the FEL frame. For those of us with zero prior experience, this can be a scary moment. LOL. I wasn't sure exactly what the darn thing was going to do next!
Have ordered ballast box and will probably use the concrete blocks. I need weights I can lift by myself easily, so will have to use more, in quantity, but that's ok.
   / Can't get bucket loader to reattach on 2210 #47
Buckie: If it is real tight just take a grinder and grind off the offending material to make it fit better. I can re-attach my loader even when the ground is not level and you should be able to do this also. good luck.
206320 (A57192)
206320 (A57192)
TANK MANIFOLD (A55745)
2021 Caterpillar 299D3 High Flow Compact Track Loader Skid Steer (A55973)
2021 Caterpillar...
2002 International 9200i Truck (A56435)
2002 International...
2012 DODGE RAM 5500 FLATBED (A58214)
2012 DODGE RAM...
2000 FREIGHTLINER CLASSIC (A58214)
2000 FREIGHTLINER...
