Cant find....
/ Cant find.... #1
forgeblast
Elite Member
nicholson, pa
John Deer 318
Hi all I am looking for 1/2'' npt stainless steel washers in 304 or 316. I just cant find them anywhere and figured the project spot was the best place to post.
I am building a homebrewing sculpture (stand, rig etc...) called the Brutus ten.
I have most of the parts but do not have the washers to hold high temp washers in place in side a brewkettle that will hold water or wort.
Galvanize out of question, so is copper and brass or bronze, just too much to worry about with off flavors and cleaning.
Any help will be appreciated.
thanks
Forgeblast.
/ Cant find.... #2
This is a store local to me. They carry all sorts of stainless nuts, bolts, screws, washers,etc. Send them an E-mail or call them with your needs. I'm sure they could ship to you in PA. This is the place I buy my own supply from as well as my work supply.
Hiawatha Fasteners Catalog Info
/ Cant find.... #4
I have an abundance of 1/2" flat washers in S/S. Would have to go check the boxes to see what alloy they are, but they were for outside long term exposure.
How many do you need? What is NPT *?National Pipe thread? or am missing something?
David from jax
/ Cant find.... #5
Can't say I've ever heard of pipe thread dimensions applied to a washer either.
/ Cant find.... #6
If you are wanting to go over the outside of 1/2" pipe you will need a washer with a hole .840 or larger. That is the outside dia. of 1/2 threaded pipe. I am afraid your only options would be bore out a 3/4" washer or use a 1" that would be loose on the pipe. There might be 7/8 washers or meteric washers that might be closer to the size you need. A 3/4 will be real close to going over the pipe.
Dan
/ Cant find.... #7
7/8 bolt size ss washer will fit over 1/2 in pipe if you are going to sandwich this between your rubber washers and 2 locknuts
and do not use brass bronze copper or galv.-zinc they are toxic.
/ Cant find.... #8
check McFeely's online - they do lots of stainles fasteners and have some washers to go with. Prices aren't always the best, but their service is pretty good.
/ Cant find....
I plan on drilling a 7/8 hold in a pot, add a ball valve on the outside with a washer and a lock nut, a full threaded piece of stainless pipe, will go through the pot, with a high temp washer, stainless steel washer and a coupler on the inside.
thank you for all the help,
its appreciated.
/ Cant find.... #11
We used to buy ready made grommet kits for tanks at work made specifically for just what you describe. Google food and milking equipment suppliers
/ Cant find.... #12
forge balst i guess we are almost neighbors I also live nicholson. waht do you neeed exactally as washer . work wth stainless all the time might be able to help you
/ Cant find....
Found them at a couple places but a guy had them on ebay for much cheaper even with shipping then any other place. Plus they were 316.
Thanks all appreicate it, once i do the build i will post pics.
/ Cant find.... #15
To help make sense of this thread
Brutus Ten ???? - Page 3 - Home Brew Forums
Brutus 10DL - a set on Flickr
2019 Chevrolet Malibu Sedan (A64557)
2019 Chevrolet...
2013 WACKER NEUSON LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
2001 Frieghtliner MT55 Chassis Step Van (A66736)
2001 Frieghtliner...
2006 Ford F-350 12ft. Flatbed Truck (A61573)
2006 Ford F-350...
2024 CATERPILLAR 279D3 SKID STEER (A65056)
2024 CATERPILLAR...
2018 FORD F-150 (A67714)
2018 FORD F-150...
