Loader Can't find Montana loader specs anywhere.
   / Can't find Montana loader specs anywhere. #1
Rowdy Redneck
Grundy
Kioti DK40SE HST
Hey everybody, as the title suggests I am looking for loader specs, specifically for the R4944 and 3940. Tractordata has nothing and I have been unable to turn up anything on Google. Any help would be greatly appreciated.
   / Can't find Montana loader specs anywhere. #2
I copied the specs when I bought my 3940..
Hey MWB, thanks for the reply! That is actually really stout.
   / Can't find Montana loader specs anywhere. #4
Any idea how to adjust pressure? My 4344 seems weak compared to those specs.
   / Can't find Montana loader specs anywhere. #5
I think there are two adjustments; one is specifically for the loader and should be located on the joystick control. The other is for the 3 point lift and rear remotes; that one should be on the control block for the rear remotes, or possibly under the foot tray where your loader control is connected.
Before adjusting I would put a pressure gauge on a loader line and check it (buy a gauge and a matching pioneer fitting, easy to check anytime). I am not sure what the pressure spec should be but I believe around 2000 - 2200 psi.
   / Can't find Montana loader specs anywhere. #6
Found a separate block that runs into loader valve. This has a nut with Allen head bolt in the middle.
   / Can't find Montana loader specs anywhere. #7
   / Can't find Montana loader specs anywhere. #8
I see the Montana 100 loader specs only are for tractor models up to 4540. Does anyone have specs for the 5740c. I have a bent rod on one of the bucket cylinders and am having a hard time finding a replacement. Any help would be greatly appreciated.
   / Can't find Montana loader specs anywhere. #9
I assume you have the curved loader arms, which would be the Model 115 loader made by Ameriquip. I've attached a Spec brochure.
Dealers are as follows:
Diamond R MO 573-455-2617
Trailswest AZ 520-586-0500
A hydraulic shop can make a new rod if need be. If you have the straight arms it's made by Ansung in Korea. I have a manual for it, but no parts support available here.
View attachment Montana 115 Loader Specs.pdfHope that helps.
   / Can't find Montana loader specs anywhere. #10
View attachment 610029Hope that helps.
I have the straight arm Ansung one. That's the problem I'm having, no one can give me specs on it. I priced out getting a rod made and they want $650 just to make a rod then I have to buy new seal kit and get cylinder cleaned and checked. I was wanting to buy a new cylinder because I'll have close to $850 in this one. From what I've found on new cylinders, they start about $200 - $600.
2021 New Holland C327 Compact Track Loader (A52128)
2021 New Holland...
Land Honor Quick Attach Pallet Grapple (A50514)
Land Honor Quick...
GIYI GY-CWG72- 72" HYD CURVED WOOD GRAPPLE (A51244)
GIYI GY-CWG72- 72"...
2018 FORD EXPEDITION (A51406)
2018 FORD...
2007 KUBOTA M5040F TRACTOR WITH LOADER (A51243)
2007 KUBOTA M5040F...
2018 KUBOTA MS-091 TRACTOR (A51243)
2018 KUBOTA MS-091...
