Tires Can't fill tire on TN 70A
   / Can't fill tire on TN 70A
SPYDERLK said:
Bob, put a jackstand or something else substantial - wood blocks, from the FLAT ground all the way up to the axle case on the side you are working on. As the tire deflates that side of the tractor will rest on this and the tire will not fully flatten and [perhaps] de bead. The valve core screws out CCW using a core tool. Some metal valve caps have them built in-a little forked spanner at the end. You may want to have a new core on hand to replace it with. There are 2 kinds. You will want the type without the exposed spring.
larry
Thanks for the details! I assume this core tool is something I can get at a local car parts store???
Bob
PS I will brace the tractor as you suggest.
Reg said:
If you have NO experience of working on tires, e.g. have NEVER taken a schrader valve apart on a car or motorcycle tire, even a bicycle tire, you will have a HUGE surprise when the air rushes out. It isn't an explosive rush, because it is at a low pressure, but there is SO MUCH of it.
I suggest you find a mechanically competent friend/neighbor/relative/whoever to do this for the first time while you watch.
I have just the friend in mind. Thanks!
Bob
   / Can't fill tire on TN 70A #13
Bob
schrader valve on Wikipedia
This is a pretty good explanation and shows the stem core tool built into many valve caps. You can find one at any auto parts store and probably Wal*Mart too. I have one that has additional thread cleaners for the inside and outside threads and looks like a little 4-way wrench "+".
   / Can't fill tire on TN 70A #14
NAPA carries the ones that go on the valve stem, in steel and are about $.40 each (forty cents). A tool will cost a little more, but I like the valve stems with them built in because they are cheap and I try to keep one on every vehicle I have, so I can find one when I need it.
David from jax
The valve repair went great! Thanks for your help. It was as easy as everyone suggested. I removed the valve, reinserted the new one as the air leaked out and only had to inflate it a few pounds. Tire never deflated enough for me to be concerned about bead coming of the rim.
Bob
2020 KENWORTH  T800 KILL TRUCK (A58214)
2020 KENWORTH...
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
Service Truck Hydraulic Rear Liftgate (A55787)
Service Truck...
2008 Kenworth T800 Semi Tractor, VIN: 1NKDX4TX68R235070, Day Cab, Cummins ISX-600 Turbo Diesel (A59076)
2008 Kenworth T800...
2014 REITNOUER MAXIMISER 48' FLATBED TRAILER (A58018)
2014 REITNOUER...
2012 DRAGON PRODUCTS CRUDE TRAILER (A58214)
2012 DRAGON...
