Can't figure out how to check my hydraulic fluid level. New Holland T2410
   / Can't figure out how to check my hydraulic fluid level. New Holland T2410 #1
Anvil73
New Holland T2410
It is on a 2010 New Holland T2410. I have a service manual and an operator's manual and have looked everywhere online with no success, so I'm hoping to tap into the knowledge here.
The operators manual shows the hydraulic fill plug to also be the dipstick, but I only have the fill plug with no dipstick.
If I stick my finger down that hole, should there be fluid that high up?
   / Can't figure out how to check my hydraulic fluid level. New Holland T2410 #2
No idea on the NH but I very much doubt you would be able to touch the fluid AT CORRECT fill from this hole.
Look around the feet area and under the seat for a dip stick. Have seen them on the back of a transmission.
Thank you for the suggestion, will do. It has a cab so will need to remove the seat etc to get under there. I can't imagine they would make it that difficult, but wouldn't be surprised. šŸ˜‚
   / Can't figure out how to check my hydraulic fluid level. New Holland T2410 #4
You shouldn't need to pull anything out. Have you check the parts diagram? Looks like it's located somewhere in the footrest area looking at the parts diagram from Messicks.
Looking at some online pictures, I see a round plug. Have tried pull it out and see if the dipstick is there?
That's it!
Thank you so much.
Silly thing for me to overlook.
   / Can't figure out how to check my hydraulic fluid level. New Holland T2410 #6
you should have a eye glass by the three point most tractor are like that ... this is from your picture looks like it right there.
Appreciate the tip. That is a top left threaded hole with a plastic plug.
4 similar holes total resembling the 4 corners of a rectangle.
I assume they're for attaching the backhoe option or something like that.
   / Can't figure out how to check my hydraulic fluid level. New Holland T2410 #8
CAT 336E (A58216)
CAT 336E (A58216)
2020 PRAT TL (A55758)
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
Meyer 7.5' Snow Plow w/Bracket (A55272)
Meyer 7.5' Snow...
2012 FORD F-250 (A58214)
2012 FORD F-250...
Dump Hopper, 43" W x 39" D (A59076)
Dump Hopper, 43" W...
