Canopy Canopy Recommendations- MF 1433
   / Canopy Recommendations- MF 1433 #1
wayne48
Vermont
MF 1433v
Anyone have any recommendations on a canopy for my 1433?
I did a quick search on the forums but only came up with info on the Tufftop, which is not as rigid as I would like- I'm thinking I'd like to mount some lights to the top. Curtis looks good but a little pricey in my mind.
Suggestions?
Thanks
   / Canopy Recommendations- MF 1433 #2
Well, it's been awhile, but if you do a search from long ago, you'll find the Wells Ag Company canopy, which is what I had. And if you go to my gallery you can see some pictures of it. Unless something has changed, they only sell through tractor dealers, but told me in the past that they'd be glad to deal with tractor dealers anywhere in the country. They build them in unpainted diamond plate aluminum or painted steel to match the tractor. Mine was rigid enough that I mounted my tiltmeters, rear view mirror, worklights, and worklight switch on it.
   / Canopy Recommendations- MF 1433 #4
I will second the WellsAg canopy. If you want a good durable canopy that will live through anything that can happen to a canopy Wells is what you need. I have had one since 1999. It has been hit, bent and everything else you can think of. I just bend it back out and it's fine.
I have the diamond plate aluminum version.
Thanks to you all for the recommendations. Again membership in this forum pays off!
Wayne
   / Canopy Recommendations- MF 1433 #6
How much height does your canopy add ? I'll be putting one on a 1540.
Gary
   / Canopy Recommendations- MF 1433 #7
Gary
With the factory Wells brackets, I would say that it adds about 2 inches. That is from memory, because I changed mine over to a slider. I built framework to allow the canopy to slide back over the backhoe seat. The framework raised the canopy a couple of inches.
   / Canopy Recommendations- MF 1433 #8
Thanks. I have only about 3" clearance between the rops and the barn door frame. I'm trying to decide between a metal canopy (wells) and a flexible/removeable one (TuffTop). I perfer the metal but with the clearance problem I may need to have one I can remove so I can fold the rops. From what I've been told the mount for the tufftop adds around 3-5" so I'll have the same problem with either.
   / Canopy Recommendations- MF 1433 #9
It looks like my options are: cut out the top of the door, let air out of tires at night, or buy a removable canopy so I can lower the rops.
Does anyone have other suggestions ?
Gary
   / Canopy Recommendations- MF 1433 #10
Gary
What kind of barn do you have?
1997 John Deere 690 Elc Excavator (A50514)
1997 John Deere...
2016 Bobcat E85 Midi Excavator (A50322)
2016 Bobcat E85...
Woods LR72 72" 3pt Rake (A50774)
Woods LR72 72" 3pt...
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
John Deere 7430 (A50120)
John Deere 7430...
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
