Canopies
/ Canopies #1
farsidejunky
West Tennessee
Yanmar YM2000B
Has anyone mounted a canopy on the ROPS of their Yanmar? West Tennessee sun can be stifling from June through August, and I was thinking about taking a flyer on one for my YM2000B.
Do you mind sharing pics and reviews?
Would you buy it again?
If so, why?
If not, why not?
Thanks!
/ Canopies #4
There are a few nice canopies out there in the 2-400 hundred range. I would might have went that route had I had something to mount it to from the start. While they are nice (canopies in general) they do get caught up branches and such and can be a pain at times.
/ Canopies #6
If so, why?
If not, why not?
Thanks!
If you already have the ROPS, you should be able to attach to it. Just do not drill holes in your ROPS. There are a wide variety of ‘U-bolts’ available at hardware stores. A bit of tubing can be worked onto them to to reduce rattle noise if desired. A bit of silicone caulk should water proof holes in the wood for the bolts. You might wish to add a bit of 1x2 or bigger close to the edges for reinforcement and allow some rear overhang for a bit of counterbalance.
All in all I see no reason why wood would not be an option if the ROPS is present.
If no ROPS, I question if you would get the necessary support from a wood frame that would fit in the area and still allow free access to the tractor function.
/ Canopies
I have ROPS.
My post regarding wood was made in jest to point out my total lack of skill in metal working.
/ Canopies #8
I have ROPS.
I have seen guys make canopies out of lots of crazy items so why not a piece of plywood? Makes as much sense as a dumpster lid.
/ Canopies #9
have you thought about a hard cab with AC and heat?. I think Tennessee gets very hot and humid in the summer..
/ Canopies
While a cab would be amazing, there are simply too many other things competing for a limited pool of money.
/ Canopies #11
My first canopy was plywood... served its purpose for a year or 2, until I built a full roll cage/FOPS. An hour or two and scraps I had around the barn... shade is nice.
/ Canopies #12
I no longer have it but once had one made out of a fiberglass basketball backboard.
/ Canopies #14
If so, why?
If not, why not?
Thanks!
A former co-worker with his YM1720D made one out of PVC and a simple deck umbrella. Very low cost and is still being used in at his place in central TN. His easy method to attach the umbrella cloth material was to use a tarp eyelet hole metal grommets with a kit found at Harbor Freight. Simple and very effective. He even make a drink holder too. Wish I had pixs of his setup. I still recall it and ponder to do the same when time allows.
Also his view was this, a purchased canopy if broken would be a problem to repair. With PVC, it's just splice, glue and go! PCV can be painted too. Make it blend in with the ROPs color.
/ Canopies #15
I went with the XLR-52 Tuff Top on my 2210BD more for rain/snow than sun. Price is reasonable and assembly is straightforward, it's a little awkward to drop in place on the mount and adjust the angle but gets easier with practice. I am happy with it and my only gripe is that it sits a few inches more to the rear than it needs to so my toes get wet (better than all of me like before). When I get ambitious I will relocate the mounting holes in the support arms to move the plastic top as far forward as possible. I went with Amaz but the total price is the same direct from All States Ag who charges less but doesn't have "free" shipping. I would have gone direct but I was concerned it might get damaged in shipping due to its size and Amaz makes that kind of stuff pretty easy. No shipping issues so I would go direct and let All States get a few more bucks.
SM
/ Canopies #16
OK, it reach a whoooooping 99F with 50% humidity here today. Hot, yet not as sticky as it was at 95F and 65% humidity earlier in the week when I had to mow. The saying, Mother of Necessity, leads to clever answers. I took what I had ...
I don't golf anymore. So, taking this rather expensive golf umbrella, I did this with 2 bungee cords.
Never thought I would say this, it's a Mary Poppins sort of Yanmar. :laughing:
/ Canopies #17
2012 EXAOS 130BBL (A65643)
2012 EXAOS 130BBL...
Front Tank Bracket (A64126)
Front Tank Bracket...
2004 CAT 247B SKID STEER (INOPERABLE) (A65643)
2004 CAT 247B SKID...
2017 Ford F-150 Ext. Cab Pickup Truck (A64556)
2017 Ford F-150...
John Deere 7230 (A64126)
John Deere 7230...
Stryker 1.5 yard Slide in Spreader Box  (A62679)
Stryker 1.5 yard...
