Cannot disengage clutch on New Hollad/Ford 2120
   / Cannot disengage clutch on New Hollad/Ford 2120 #1
Zerk
Wisconsin/UP
New Holland 2120
My rear PTO, (only PTO) will not disengage. I pull the lever back, it doesn't go all the way back and sounds funny. I have tried leaving the clutch in for maybe 20 seconds. I have tried going forward and backwards.
I don't have any attachments that use PTO yet. My guess is it got bumped, by putting chainsaw behind seat. Starts now if I put clutch in. Previously only had to have both shifters in neutral.
I want to get a few things down this weekend. Does it hurt to just let it run unloaded?
I don't see any pins or adjustment points. I see a rod with on pin, no other holes, or rods and nuts.
Odd thing is, I could have sworn I put the clutch in when trying when problems starting. Though I think I was having separate electrical problems. If I charged it on 10 amps for 10 minutes it would start, clutch no pushed in.
1995 Ford/New Holland 2120 diesel Shibaura 4x4
Thanks for any help.
I just realized I screwed up the title to the thread. I meant PTO, not clutch.
Any mods that could fix?
Used it for a few hours today. Still cannot get the PTO to disengage. Lever will not go all the way back. Where it stops, sounds bad, so I engage it.
Pto lever needed to come an inch forward to disengage. Odd, you would think all the way back would do it.
2015 CIMC 40FT CONTAINER CHASSIS (A52141)
2015 CIMC 40FT...
2006 Toyota Highlander SUV (A50324)
2006 Toyota...
2015 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2015 KENWORTH T680...
1996 Lincoln Town Car Signature Sedan (A50324)
1996 Lincoln Town...
2012 International ProStar T/A Day Cab Truck Tractor (A50323)
2012 International...
