Can you widen the axles on all tractors
   / Can you widen the axles on all tractors #1
dirtwhisperer
Lancaster County , PA
I have seen posts referring to widening the stance of the tractor by making the axles wider. Is this an adjustment on the tractor that is easily done or what are they referring to ?
   / Can you widen the axles on all tractors #2
Start with a 2wd wide front end and look for bolts. Those are the only ones you can do it on without a welder and a knack for inventing /forums/images/graemlins/grin.gif
Depending on the rim, you can widen out your rear (did that sound right??) by flipping the wheels convex to concave. Remember tread though, you have to swap sides to keep the tread direction correct. Some of the rims have a place where you can flip the rim after you have flipped the wheel and get pretty wide.
   / Can you widen the axles on all tractors #3
actually, any tractor, 2 wd or 4wd can be widened as long as they have bar axles!!
Take care
Will
   / Can you widen the axles on all tractors #4
</font><font color="blue" class="small">( Is this an adjustment on the tractor that is easily done )</font>
Easily done on some, harder to do on some, and impossible to do on others; i.e., some tractors are designed so they can be changed and some are not.
   / Can you widen the axles on all tractors #5
I have a Mahindra 2810 HST and I can't.
I also have a Kioti DK40 and I can.
   / Can you widen the axles on all tractors #6
Dirtwisperer, glancing through my manual, which covers the Kubota Grand L Series models 3130 thru 5030, it states:
Two wheel drive models - you can adjust the front axle out about 12".
Four wheel drive models - the front wheels/axle cannot be adjusted.
The rear wheels - on the two and four wheel drive models - can be adjusted by changing the position of the rim and/or disk (about 12") also.
As you can see, Bird again has the correct information.
This forum keeps my manual from gathering dust and I learn a lot also. /forums/images/graemlins/smile.gif
   / Can you widen the axles on all tractors #7
Then for those that can not be adjusted or are already at max one can use axle extensions (see www.unverferth.com fairly pricy though) or wheel spacers. A number of threads have appeared on this topic.
   / Can you widen the axles on all tractors #8
</font><font color="blue" class="small">( I have a Mahindra 2810 HST and I can't.
I also have a Kioti DK40 and I can. )</font>
And I have a Kioti CK20 which can be widened a little only if using AG tires. The turfs and Industrial tires are already so wide, there's no more room for widening.
On some tractors, you can widen them out without swapping sides as they have a design that "spins" out keeping the tire tread going in the proper direction. Generally, you'll get the widest stance by swapping sides on those tractors where fenders are designed to handle this. John
   / Can you widen the axles on all tractors #9
2wd front axles that are bar or pipe can generally be widened. In some cases front and rear tires can be dished out. And in very limited cases, the rear axle splines protrude out the hubs of the rear wheels.. letting you slide and position that rear wheel anywhere onthe axle spline you want. Lots of larger ag tractors are like that as well as many of the older JD's
Soundguy
NEW Skid Steer 72'' Sickle Bar Mower (A59000)
NEW Skid Steer...
2023 BOBCAT T770 SKID STEER (A52709)
2023 BOBCAT T770...
JOHN DEERE 7210R TRACTOR (A54756)
JOHN DEERE 7210R...
2016 FORD F-250 SUPER DUTY (A58214)
2016 FORD F-250...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A56435)
2003 International...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
