Can you weld engines together?
   / Can you weld engines together? #41
You could use love joy couplers (spider joints), this way the engines would not have to line up perfectly. They come in any shaft size and can hold more torque than those engines could ever supply. Twenty years ago , I was maintenance mechanic & welder at IBP. We used these on large electrical motors. All of your engines will run even, because the faster or stronger one will pick up the slack of the weaker one. Check out clearstreamco
   / Can you weld engines together? #43
Flex coupling joints is exactly what Detroit does with their 3000 HP V 20 diesels. They have a V8 in the front, a V8 in the rear, and a V4 in the center all bolted together with the crank shafts coupled with flex couplers. These make a locomotive sound quiet. 9 foot radiator fan with 8 blades that makes most small plane engines look small. 3 turbochargers. Radiator, without fan, weighs 8000 lbs and holds 250 gallons of coolant. Outside the noise they run smoother than some of the smaller cat V16s ( 3516), bottom line, not a new idea. Be fun to try.
Chris
2018 John Deere 30G Mini Excavator (A56857)
2018 John Deere...
2016 Dodge Ram 5500 4x4 Crew Cab Stellar 4421 4,000lb 2 Ton Crane Service Truck (A55973)
2016 Dodge Ram...
2013 Ford Explorer AWD SUV (A56859)
2013 Ford Explorer...
2008 Sterling Acterra Ambulance (A56858)
2008 Sterling...
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A57192)
2008 INTERNATIONAL...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
