Can you tell what is wrong with my Ford 8N's engine?
   / Can you tell what is wrong with my Ford 8N's engine? #11
Clean the fuel tank and all the fuel lines. Replace the fuel filter. Test the engine. Post back with the results. I've owned six old tractors and all of them had crud in the fuel tank when a got them home.
Good luck.
   / Can you tell what is wrong with my Ford 8N's engine? #12
No pto safety shield. No live pto. No drawbar. No live hydraulics, no SCV, first and reverse are too fast. Brakes are barely sufficient when in 100% condition. The N tends to flip and crush the operator.
   / Can you tell what is wrong with my Ford 8N's engine? #13
Sounds like a love affair to me!
   / Can you tell what is wrong with my Ford 8N's engine? #14
We can say that today but when they were built think about what they replaced Horse, Mule, Ox hand labor !!! Give the old Machine's a break they were true innovators and brought us to where we are today.
   / Can you tell what is wrong with my Ford 8N's engine? #15
No pto safety shield. .
but you could get one as an add on, including an sae adapter, so they were available.
No live pto. .
Live pto upgrade was available via aux tranny, essentialy a pinion clutch.
No drawbar..
They DID have provision for a drawbar! all 8n rear sections were drilled and tapped for the bolt on plate that allowed use of a swinging drawbar. They were extremely common. 9n/2n rear sections were not drilled/tapped for this option.
Brakes are barely sufficient when in 100% condition..
This means you have not actually operated one that had 100% condition brakes. That means good non worn OE style drums, new fit shoes, not greasy ones on wallowed out greasy drums. good springs, correct adjustments. 8N and NAA brakes are he same. in fact all the dry setup brakes are the same fromt he 8n+ except after the naa the hub design was better to prevent oil leakage. 9n/2n have a different drum and brake setup. correct adjusted 8n brakes in good repair will lock tires. if you havn't observed this, your unit was out of adjustment or not in good order, as will all the later models with dry brakes.
this is operator error, not machine failure. any tractor used incorrectly can flip. It's physics and geometry. pull from above the rear axle, and you canmake a situation where the the machine will rotate around the axle. You prevent this with a little common sense and safety and pull from BELOW the axle. To blame this on the tractor shows that the operator does not understand middle or high school level geometry!
Live hyds is attainable as are SCV's, as noted above, with addition of extra equipment and cost.
PS... and I don't even particularly like the N.. I much prefer 55-64 models... but if one is going to complain.. one might at least get the facts straight... ;)
2024 AGT KFE-20 2,000lb Electric Forklift (A50322)
2024 AGT KFE-20...
2017 Ford F-650 Mason Dump Truck (A50323)
2017 Ford F-650...
2020 CATERPILLAR 301.7CR EXCAVATOR (A51242)
2020 CATERPILLAR...
2017 RAM PROMASTER 2500 CARGO VAN (A51222)
2017 RAM PROMASTER...
2019 Energreen EVO 40 Robotic Tracked Flail Mower (A52128)
2019 Energreen EVO...
1985 Toyota Pick Up Truck (A50515)
1985 Toyota Pick...
