can you tell the truck subtype trim package from the vin #?
   / can you tell the truck subtype trim package from the vin #?
Why not go to the dealer.Get the correct part number, then shop around for the best price.
1, i don't have the time to hang out at the closest dealer with is over a city away.
2, our delaer isn't the sort that gives out part info...
   / can you tell the truck subtype trim package from the vin #? #12
A phone call to the parts dept. would do it. Did you check with the dealer or are you guessing they won't do it.
I'm guessing you didn't read my message or are trolling, I'll stick you on ignore now. ( yes i did call the dealer, no, they would not give me a part number ), yes, they were about 7 x as expensive as the ones i can find online, now that i know what to look for.)
So no, a phone call to the dealer 'would not do it'
I'll take a look after work, thanks
   / can you tell the truck subtype trim package from the vin #? #17
Since yours is a Classic, I think the only difference is between dually and not dually trucks. Dually trucks had a raised black plastic trim surrounding all the lights. Non duallys also had a black border around the lights, but it is flush not raised. Earlier trucks (approx. 2003) had flush red borders around the lights. Also assuming you have the yellow turn signal lenses.
With aftermarket lights, some are NSF certified and some are CAPA certified. Most insurance companies, prefer CAPA certified parts.
   / can you tell the truck subtype trim package from the vin #? #18
If this has "box" and was not a chassis cab unit. GM part number 19169021 left, 19169022 right.
It was a pickup, not cab / chassis. I tried classicmslt and SLT in the match up boxes, and it did not effect the lamps any, though some other trim packages did, so I think I have a correct OE style lamp coming.
UNUSED CFG Industrial QK18R Mini Excavator (A47384)
UNUSED CFG...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
Caterpillar D5K2...
19008 (A48082)
19008 (A48082)
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
