Can you tell me if a 7108 loader can be mounted on a Ford 3930
   / Can you tell me if a 7108 loader can be mounted on a Ford 3930 #1
horse97
nj
Can anyone tell me if a 7108 loader can be mounted on a Ford 3930
   / Can you tell me if a 7108 loader can be mounted on a Ford 3930 #2
Anything can be done given enough money and or time & talent. But a 7108 on a 3930 is just a bad idea. A 7108 is designed to fit a tractor with 2/3 the HP and 1/2 or less the weight of a 3930.
   / Can you tell me if a 7108 loader can be mounted on a Ford 3930 #3
I have the larger 7109 fel on a 2120, still a smaller rig than the 3930. It's rugged though newer ones will lift more. I don't think you'd want to put even a 7109 on a 3930. Still, as Rick says, you could!
Jim
   / Can you tell me if a 7108 loader can be mounted on a Ford 3930 #4
Jim
Actually, there was a mount kit for a 7109 to go on a 2WD 3930. There were a few State bid rigs around with that combination. Pretty lame.
   / Can you tell me if a 7108 loader can be mounted on a Ford 3930 #5
The 7108 is way too weak for that size tractor. I have it on a Ford 1920 and wish it was stronger.
Thanks for the info,How about 7210 will that work
2016 CATERPILLAR CT660 TRI AXLE DUMP TRUCK (A51222)
2016 CATERPILLAR...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
ALLMAND 45KW MAXI POWER GENERATOR (A50854)
ALLMAND 45KW MAXI...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A51039)
Koyker Loader...
2014 Therm Dynamics TD400 Towable Flameless Heater Trailer (A49461)
2014 Therm...
2010 L3 GENERATOR SET (A51222)
2010 L3 GENERATOR...
