Can you tell me if a 7108 loader can be mounted on a Ford 3930
   / Can you tell me if a 7108 loader can be mounted on a Ford 3930 #1
horse97
nj
Can anyone tell me if a 7108 loader can be mounted on a Ford 3930
   / Can you tell me if a 7108 loader can be mounted on a Ford 3930 #2
Anything can be done given enough money and or time & talent. But a 7108 on a 3930 is just a bad idea. A 7108 is designed to fit a tractor with 2/3 the HP and 1/2 or less the weight of a 3930.
   / Can you tell me if a 7108 loader can be mounted on a Ford 3930 #3
I have the larger 7109 fel on a 2120, still a smaller rig than the 3930. It's rugged though newer ones will lift more. I don't think you'd want to put even a 7109 on a 3930. Still, as Rick says, you could!
Jim
   / Can you tell me if a 7108 loader can be mounted on a Ford 3930 #4
Jim
Actually, there was a mount kit for a 7109 to go on a 2WD 3930. There were a few State bid rigs around with that combination. Pretty lame.
   / Can you tell me if a 7108 loader can be mounted on a Ford 3930 #5
The 7108 is way too weak for that size tractor. I have it on a Ford 1920 and wish it was stronger.
Thanks for the info,How about 7210 will that work
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
Woods BW12 Batwing Mower (A50514)
Woods BW12 Batwing...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52128)
REYNOLDS 100 - 8...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2018 Ford F-350 Crew Cab Pickup Truck (A50323)
2018 Ford F-350...
UNUSED RAYTREE EXCAVATOR MULCHER (A50460)
UNUSED RAYTREE...
