Can you run both PTO's at once?
   / Can you run both PTO's at once? #11
Re: Can you run both PTO\'s at once?
My 33 has two separate levers. You can run both at once. I've done it but with nothing attached to the mid one.
   / Can you run both PTO's at once? #12
I run both at the same time on my BX2200. Mid = 60 inch MMM and the rear = grass catcher. Plenty of power for my combination of implements.
John
   / Can you run both PTO's at once? #13
</font><font color="blue" class="small">( My 855 (and I believe the entire x55 line) has a three position selector for mid, rear or both PTOs engaged.
(At least I think it does...I am not home now, so I can't go check)
)</font>
It does. At least mine does, and I assume it's standard.
A problem with running both PTOs on a small tractor is that can add up to a lot of horses.
   / Can you run both PTO's at once? #14
I know you CAN run both PTO's on a Class I Boomer at the same time. Don't think I would, but you can.
Thanks for the info guys. I do have two PTO levers on my tractor. I wasn't planning on keeping the rear PTO engaged all the time. It is just for the ends of the field. Basically I want to be able to back up after my turn and wipe out 4' of vegetation without disconnecting the MMM PTO. I will then disengage the rear PTO until I get to another end of the field.
   / Can you run both PTO's at once? #16
</font><font color="blue" class="small">( Basically I want to be able to back up after my turn and wipe out 4' of vegetation without disconnecting the MMM PTO. )</font>
<shrug> If it stalls the tractor, you'll know it doesn't work. I don't think you'll break anything.
   / Can you run both PTO's at once? #17
On an L3710 you have to run the rear pto at the same time as the mid pto for the mid pto to operate but you're not supposed to load both ptos at the same time. On the Case I can run any combination of the front, mid or rear PTO's.
Year: 2019 Make: Chevrolet Model: Tahoe Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 96,127 (A48082)
Year: 2019 Make...
PALLET OF TILE FLOORING, ARMSTRONG (A50460)
PALLET OF TILE...
2015 Geringhoff NS830 (A47164)
2015 Geringhoff...
Hyster H40 Forklift (A48837)
Hyster H40...
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
377854 (A48836)
377854 (A48836)
