Can you ID this farm implement?
   / Can you ID this farm implement? #1
gwfami
1969 JD 4020
Hi,
We have had this on our farm since the 1960's, when I was just young. I'm pretty sure that it's an Eversman automatic land leveler that telescopes, but there are no readable id marks on it. Since I am the last of the clan, I don't have anyone to ask about it. It's going to be auctioned off with the rest of our farm equipment so I'd like to know what it is, as google hasn't been a great friend in this case.
Thanks,
gwfami
   / Can you ID this farm implement? #2
Definitely a land leveler - like a road grader. Brand - ??
   / Can you ID this farm implement? #3
They used to be called a land plane, they where common in flood irrigation country to get a field level before planting and corrugating for irrigation using siphon tubes out of ditches and gated pipe.
You couldn't have any high or low spots or your water wouldn't go where is was desired.
Usually the box blade was more in the middle some would even have a blade shaped similar to a wing behind the wheels to help in compacting and leveling a field while maintaining the required slope for the water to flow/
Thanks,
We used it to work our roads and pipe irrigated land (not siphon tubes, but irrigation pipes). Any idea what brand/model it is? This particular one could hydraulically telescope to make it longer/shorter as you desired. A friend thinks they have found an additional extension to make it even longer in a weedy part of the land.
Google doesn't show anything like this with the roller in front and the ability to telescope.
   / Can you ID this farm implement? #5
The only one I was familiar with was eversman they had several models.
Know of any pictures/history or that sort of thing? I'm not finding much on eversman online.
   / Can you ID this farm implement? #7
Not really, sorry
2017 Big Tex 10ET T/A Flatbed Equipment Trailer (A50322)
2017 Big Tex 10ET...
2017 FORD F-650 FLATBED DUALLY (A52472)
2017 FORD F-650...
3 Point 5 1/2ft Metal Screen Cargo Carry (A51573)
3 Point 5 1/2ft...
2007 DEUTZ D 2011L03 MOTOR (A52472)
2007 DEUTZ D...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
