Mark_in_NH
Veteran Member
- Joined
- Mar 4, 2002
- Messages
- 1,555
- Location
- Moultonborough, New Hampshire
- Tractor
- New Holland TC35D w/ 16LA FEL
Hi Everybody,
I finally have an update in the light department. The canopy hazard lights work properly and as desired. A friend of mine who works for a local company that sets up Emergancy, Municipal and Private vehicles, gave me a Federal electronic flasher unit that he salvaged out of a cruiser retrofit. It and the lights work like a champ. I had 2 problems from the start, both of which were suggested to me in this thread.
1st. was the type of flasher I was trying to use, a Wagner type.
2nd. was the size of my test wire I was using to provide temporary power.
I took a few minutes to day and tested everything, using the posative side of my jumper cables ( I figured they should be of aequate size ) to provide temporary power.
Everything worked as intended. Now I just need to figure out the path to run my hot wire (need to buy some) to the rear of the tractor and up to the canopy, mount my switch, make all my final connections.
Thank you all for you advice, suggestion and input.
